Can't Upload Images!
Whenever I try to upload an image, I get an error message telling me my image is too large. The smallest size my scanner will scan a picture is 3.9KB. When I change the settings to something smaller, the program automatically bumps it back up to 3.9. How can I post pictures??
scan at the LOWEST resolution, or you need to re-size in some kind of picture program, save as a jpeg, and use a low resolution options too, if you have it
3.9 kb is not much. You mean 309? Anyway, a try resizing the image or croping it to make it smaller, that will lower the filesize. I don't know what program you use, but you may be able to adjust the compression to make it a lower quality picture. Also, .jpg and .gif files are generally very small in file size. .gif is usually the smallest in my experience. Good luck,
-Tim |
try reading your scanning software instruction manual. and i don't think you mean 3.9k...that's miniscule file size.
http://home.pacbell.net/nirky/turbo_120.jpg |
| All times are GMT -8. The time now is 03:56 PM. |
