Send a message via Yahoo to neildeshpande
<944> Leaking Power Steering?
Gruppe:
I am losing power steering fluid. Losses are high when the reservoir is full, but slow down when the reservoir drops in level. I've tried to place mats under the car to tell where it is coming from, but it appears to drip from a transverse line, more or less along the rack.
Just 15 mins ago, I finished a comprehensive degrease of the underside of the car, removing several years' of gunk. What a great feeling to see all that aluminium shine through! I'll be watching for leaks every few days.
However, if there are some 'usual suspects', I'd appreciate a listing so my search space is reduced.
Thanks!
Neil Deshpande
1987 944 NA 5-sp
Old 01-04-2004, 09:17 AM
SoCal Driver's Avatar
The small tubing going from boot to boot is just to ballance the air pressure between the two sides. If ATV is leaking from it or that area then you need to reseal the rack.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 01-04-2004, 09:30 AM
Let's go shooting.
Dark Skies's Avatar
The leak can often be very deceptive though as it often runs down from the central pipe to the reservoir. In my case the rubber had gone manky and was leaking at the top of the pipe. You'll probably find the sway bar rubber beneath it has gone too as the ATF buggers it up (goes soft and useless).
Note how I resisted making a lewd comment at that latter part. I must be getting all mature and stuff since I married.
1983 944 Lux (manual) 2.5 litre 8 valve na and no pas
1991 944 (automatic) 2.7 litre 16 valve na and pas
"I have only five words for you: From my cold, dead hands."
Old 01-04-2004, 11:12 AM
AFJuvat's Avatar
Other common leaks:
The return line that runs from the top of the rack to the lower tube on the tranny oil cooler
Pressure line from pump to rack
Return line (which encompasses the cooler and the line up to the reservoir.
Pull your boots off of the rack a little bit - if fluid comes spilling out, it is your rack that is leaking.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 01-04-2004, 08:23 PM
fast924S's Avatar
Send a message via AIM to fast924S
I had the same problem with my 924S. when you get a chance have some one look under the car while you turn the wheel lock to lock. My bet is that your rack is leaking into the boots because the seals are bad in the steering rack or your rods instide the steering rack are rusted and not sealing right. In any case if this is true you will see fluid squirt from the boots. You will have to have you steering rack resealed or get a rebuilt one. I found that new racks are alot of $$$$
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 01-05-2004, 12:37 PM
