Unhappy Bad noises...
Hey...
Driving along today on my way home from work and had to make a really quick lane change and break at the same time. I almost missed my turn. Anyway, now every time I turn the wheel even a little left I get a repetitive noise that sounds like the brake is rubbing. The sound goes away at about 30 mph or so and the interval varies with speed. I just replaced wheel bearings 1500 ago and adjustment and alignment are fine. Any ideas guys...help.
Erik
'87 951
Go the distance....
Old 08-20-2001, 04:22 PM
DennisR_944's Avatar
Post
Check your front sway bar bushings.
Dennis Russell
Dennis Russell
Indianapolis, IN USA
1987 944 n/a
Old 08-20-2001, 04:28 PM
Post
For wear or...you'll have to excuse me my knowledge is a little spotty in some places.
Erik
Go the distance....
Old 08-20-2001, 06:22 PM
Post
Just check that they're still in one piece and fit tightly in the holders. If there's a problem with them, you'll see it.
Dennis Russell
Dennis Russell
1987 944 n/a
Old 08-21-2001, 02:16 AM
Post
Thanks for the help. They don't look too bad...upon further investigation, the intermittent noise changes pitch and eventually goes away when I press the brake. Again only happens when I go left. Could this be a tie rod about to **** itself?
Erik
Go the distance....
Old 08-21-2001, 07:49 AM
Post
sorry to bring this back up but... I was trying to find the source of the noise today while I was working on the car and discovered that the noise is actually from the left rear wheel area. This would change the list of possibilities. Nothing looks obviously bad but...cv's maybe?
Erik
Go the distance....
Old 08-28-2001, 08:25 PM
Bob's944's Avatar
Send a message via AIM to Bob's944
Post
brake rotor?
Old 08-28-2001, 08:49 PM
