944 S, 1988, won't start.
Hi,
My 944 will not crank - sometimes. Sometimes it does crank flawlessly, but sometimes, like this morning, it won't crank - especially when I need to go to work.
It makes no noise at all! The starter doesn't turn and the battery is good. Is there a relay?
Help!!
Kerry
Old 01-06-2004, 05:38 AM
SoCal Driver's Avatar
No relay just the ignition switch sending current to the starter solenoid which in turn closes the contacts between the starter motor and the battery through that thumb size cable.
So if you have power in the car but no starter engagement/cranking then there is a problem with the cable, the solenoid or the starter motor.
If the starter is spinning but not engaging the flywheel the spring loaded device (bendix) is stuck or frozen.
The large battery cable does tend to corrode and increase resistance at the battery connection. Sometimes even breaks off inside the insulation.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 01-06-2004, 06:12 AM
..P ..P is offline
I'd look at the battery cable connections, as noted in the prev post. Also note, there are three relays in some 944 cars, such as my '90 S2, which control "ignition" related components. Not sure how this relates to your problem, but if the battery cable is tight, and you have a good ground connection from negative terminal to the body, and a good connection onto the starter too, then I'd go after the ign switch as stated (and all relays)
P
1983 928S 5-speed, 1984 944, 1990 944S2 Cabriolet
My other car is a Chris Craft Commander
http://www.chriscraftcommander.com
Old 01-06-2004, 07:18 AM
Just checked the electricals to be sure. Straight shot from the ignition switch to the starter solenoid. Unless you have an automatic then there is a switch on the shift lever.
Old 01-06-2004, 08:09 AM
It was the starter. 7v at starter, not 12.
Old 01-06-2004, 02:53 PM
What? You mean the cable between the battery and the starter? Or?
Old 01-06-2004, 04:37 PM
Yeah, using a multimeter we measured the voltage at the starter when the key was turned to the start position and got 7v. When we measured the wires (not the starter), we got 12v.
Old 01-07-2004, 08:51 PM
