entertaining the idea
UconnTim97's Avatar
Frozen door lock
Today was the first day here that it was well below 32F. My drivers side door lock appeared to be frozen. I went in through the passenger side and was able to open the door that way.
It works fine now that I unlocked it from the inside, aside from being a little stiffer than usual.
Any way to prevent this from happening again?
There are some who call me... 'Tim'.
a well set-up 1983 Guards Red 944
Old 01-07-2004, 02:49 PM
Chris_924s's Avatar
I had the same thing happen yesterday.. a little PB Blaster or WD40 on the key will displace any moisture. Spray a little on the keyhead and work the tumblers back and forth a few times. It should work quite well. You can also squirt a little powdered graphite in there as well once the moisture is gone.
Dont force the key... let it warm up before trying this.
TENSION YOUR SOCKS!
88 924S Guards/ Black ~ 10 years as a Daily Driver and STILL SMILING!
87 NA Diamond Blue Metallic ~ Gone
Old 01-07-2004, 03:10 PM
UconnTim97's Avatar
Thanx, I'll give that a try....
Old 01-07-2004, 03:20 PM
