I get my tax refund next week and the wife gave me the go ahead to spend it on the car. The only problem is I am undecided on what to get. Should I get the bursch muffler to go with the header I am putting on tomorrow or the jacobs ignition. I was also thinking about some cross drilled rotors up front.
If you are a street driver forget cross drilled rotors unless you have money to burn! If your rotors need attention just get them turned. Headers, Jacobs plug wires ($50 ) +4 Bosch plugs, MSDS air filter ($120)and good exhaust with the headers. Take the cat off if you can where you live. Put syntheic (mobile 1) oil in your engine and also Mobile 1 synthic gear oil in your transaxle. Other good oils around but Mobile 1 is real good and decent price for synthetic. Using synthetic in the engine and transaxle will pick a little speed up. A chip may help a bit too! It all adds up.
[This message has been edited by T86951 (edited 09-01-2001).] [This message has been edited by T86951 (edited 09-01-2001).] |
