88_944's Avatar
Can the 944 engine take 6000 RPMs?
I was thinking of getting a Weltmeister Performance chip that gives a 15 hp @ 6000 RPMs and I was wondering if the engine could handle the high RPMs without damaging. I think because the 944 has no rocker arms setup, 944 could take more RPMs.
I finally got an intake!
My Black 944
My Gaming Forums. Xbox360gen.com
Old 01-06-2004, 09:19 PM
ilikemy944's Avatar
Send a message via AIM to ilikemy944
Well, stock redline is 6400rpm.
I've run mine to around 7000 a couple times (not recommending this tho). O, I continally see that 6500 number, lots,
<-- Maniac.
No probs yet, 180,000 miles.
Brad Tompkins
Current: '86 951 Sunroof Delete - '89 951 - '83 944 Spec - '08 Cayenne Turbo
Past: '88 924S Track - '86 944 16v - '87 951 - '87 951 - '88 951S - '08 Cayman S - '87 944 Track - '93 968
Old 01-06-2004, 09:34 PM
ilikemy944's Avatar
O, and I'd recommend the chips at www.frwilk.com big time over the weltmeister chips. And I promise you will not get 15hp.
Brad Tompkins
Old 01-06-2004, 09:35 PM
SoCal Driver's Avatar
Don't say too long above 6,500. The hydraulic lifters float and the valves hit the pistons.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 01-06-2004, 09:56 PM
Looks like a stock intake to me.
Old 01-06-2004, 09:59 PM
88_944's Avatar
Really?
My Black 944
Old 01-06-2004, 10:17 PM
scheistermeiste's Avatar
Send a message via AIM to scheistermeiste Send a message via Yahoo to scheistermeiste
hehe it appears that the intake is stock but the filter is aftermarket to me...
Special Edition 924S 1988 <- SOLD!
Asking if you should replace that timing belt is like asking if you should re-use a condom that may have in hole in it with a hooker.
Old 01-06-2004, 10:31 PM
Well you do have that funny looking filter on the AFS. But that is not the intake. The intake is from the throttle body to the head. Those long silver tubular things. Guess with the 944 you could include the AFS.
Old 01-06-2004, 10:32 PM
intake = intake manifold or the whole set up?
'86 951 blk/blk
-968 M030 Sway Bars with delrin bushings
-IceShark headlight kit
-Koni Yellow Sport Adjustable struts and shocks
-225 lb springs up front
Cleaned grounds = happy 944
WTB: 951 black passenger door/fender
Old 01-07-2004, 01:29 AM
Send a message via AIM to TheCooler
Of course a well maintained engine can. Its ment to go up there. Anyways take off the K&N and put the stock setup back on.
-2002.5 GTI VR6 24V 6SPD
-Kalahari Beige 89 Porsche 944S2
-87 VW GTI 1.8 16v
-2007 Ford PIMP(free)star ...company car....
-1999.5 Jetta VR6
Old 01-07-2004, 03:20 AM
Of course, the number of times you actually use 6,000rpm are..........
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 01-07-2004, 05:48 AM
Always considered the filter seperate from the intake. Works with or with out it. Even a different one than was designed for it.
Old 01-07-2004, 07:28 AM
Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
most people that I talk to that installed a cone filter on their car say, "check it out, yo, i got a new intake." and I say, "no, you didn't."
Just a thought: since the cone filter has no external routing source, it is basically using hot engine bay air to feed the engine; the stock airbox, however, uses cold air from the driver's side wheel well. Wouldn't one be better off, then, with the stock air box?
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944.
Old 01-07-2004, 07:33 AM
One of the factory bulletins has you cutting off the intake snorkel about half way to the fender and plugging the hole in the fender well.
Old 01-07-2004, 07:39 AM
ae1969's Avatar
Send a message via ICQ to ae1969
At 6000 rpm in spirited bursts is nothing to be concerned about....
If you will be tracking the vehicle and are planning on keeping it close to redline for sustained periods of time..... I would be more concerned about starving #2 rod bearing. This is a real issue.
Valve float can/will happen at 7000+rpm. That valve train is not designed for sustained use at that rpm. At this point you are looking at stronger springs etc....
There is a guy up here that runs his 944 Turbo on a stock head pushing over 25 psi for track use. He has yet to experience valve float........... He runs the quarter mile on this vehicle as well.... If you haven't seen a turbo at +20 psi flying past the redline on every shift ... YOu havent lived.
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 01-07-2004, 07:43 AM
87924gt's Avatar
I HAVEN'T LIVED!!!
My life is great!
Prev. rides - 87 924GT, 86 Carrera, 69 Targa, 85.5 944 track car, 86 951
84 Triple Black 911 - Current
Old 01-08-2004, 04:12 PM
MrPants's Avatar
why? water?
84 944 Non Alcoholic
Old 01-08-2004, 04:14 PM
ilikemy944's Avatar
yeah... lots of engines coming in for repair with hydrolock (that the right term?) water in the cylinders...
Brad Tompkins
Old 01-08-2004, 04:24 PM
bryanthompson's Avatar
Send a message via ICQ to bryanthompson
so... how many of us have cut the snorkel and plugged the whole, and is it worth doing? If the bulletin says to, I'd assume it's credible. If done, do you re-route the intake to somewhere where you don't get the water? Maybe putting some kind of water-deflector in the fender or something would fix that. I dunno, just wondering.
1983 944 - Sable Brown Metallic / Saratoga / LSD : IceShark Light Kit
Old 01-08-2004, 05:42 PM
Roger Hall's Avatar
Very true
Sounds like they are advertising the max HP gain at the top of the power band. Will the motor hold togeather? Depends on the milage and how long you keep it at 6K.
Roger Hall
81 924 N/A
Some people are like Slinkies. Not really good for anything, but you
still can't help but smile when you see one tumble down the stairs.
Old 01-08-2004, 06:28 PM
