Ignition Switch
Well I need a new ignition switch.......found one for about 50 bucks
http://www.overnightautoparts.com/porsche-944-944--001-ignition-switch.html
thought they were cheaper than that for some reason.....anyone know where to get a better deal?
1987 porsche 944
Old 01-15-2004, 11:26 PM
SoCal Driver's Avatar
PelicanParts
http://www.pelicanparts.com/catalog/shopcart/944M/POR_944M_electr_pg7.htm
M-613-012-00
$40
Buy from them as they give you this forum with out dunning you for $19.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 01-15-2004, 11:40 PM
Made a little purchase
You have sent a request to purchase:
Item Name Item Price Quantity Item Total
M-613-012-00
Electrical Portion, Ignition Switch, 911 (1970-89), 944/968 All from 2/85, 928 (1978-95)
$40.00 1 $40.00
- Typically ships within 24 business hours.
OC-142
Mahle Oil Filter, 924S/944/968 All, 911 C2 Turbo (1991-94)
$4.75 3 $14.25
J-123-011-20
Oil Drain Plug Seal (22 X 27mm), Sealing Ring for Plug at Bottom of Engine Sump Plate or Oil Tank, 911/911 Turbo (1965-89), Air Box Sealing Ring, (22 X 27mm) 911 (1974-83), 944/944S/944S2/944 Turbo/968 (2/1985-95) 22 X 27mm
$0.25 1 $0.25
- Typically ships same or next business day.
E-106-237-07
Lower Radiator to Water Pump Hose, 944S, 944 from 2/85
$12.65 1 $12.65
K-512-385-02
Hose Clamp (to Radiator), 944S2 (1989-91), 944 Turbo (1986-89), 968 (1992-95)
$2.75 1 $2.75
- Typically ships next or 2nd business day.
K-512-390-00
Hose Clamp, to secure the above filter, 911 Carrera (1984-89)
$5.00 1 $5.00
E-106-129-05
Thermostat, 924S, 944 thru 88, 944S, 944 Turbo thru 88
$9.50 1 $9.50
PEL-RP6944D
Stainless Steel Brake Lines Set of Four (DOT Approved), 944 (1983-89), 944 Turbo (1985-87), 968 (1992-95, without Club Sport Option)
$49.75 1 $49.75
- This part may be shipped directly from the manufacturer.
F-110-253-00
Fuel Filter, 924S, 944, 944S, 944S2, 944 Turbo
$17.50 1 $17.50
PEL-H4-70476
Hella H4 Halogen Headlamp Upgrade Kit, each, 2 req per car
$47.50 1 $47.50
PEL-DPR-5773
17mm Transmission Drain Plug Removal Tool (3/8 inch drive), 911/912 (1965-86), 911 Turbo (1976-88), 914 All, 924S/944, 928
$8.95 1 $8.95
- Typically ships in 3 business days.
- This item is non-returnable except for warranty replacement - applies to books, tools, and electrial items .
Subtotal: $208.10
Shipping: $11.85
Taxes: $0.00
Total Price: $219.95
1987 porsche 944
Old 01-16-2004, 12:45 AM
ae1969's Avatar
Send a message via ICQ to ae1969
Its addicting buying from pelican........
In a good way.
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 01-16-2004, 07:18 AM
I even buy parts for the wife's old Toyota Celica from Pelican!
Old 01-16-2004, 07:29 AM
So I am putting in my own ignition switch for the time being. a push button underneath the driver seat......should be pretty tech.
i will post a picture in a minute
1987 porsche 944
Old 01-16-2004, 05:50 PM
Sweet push button start.
So I wired up a 'temporary' ignition switch in my car due to mine having a failure. I used a 15 amp fused power directly from the battery to inside the car. I then hooked up another line coming from the ignition switch jumper (right side firewall harness...red wire, white plastic jumper. mime had a blue one too.) also inside the car. I then hooked up both wires to a push button switch and mounted the switch inside of my ashtray....it is pretty sweet. Works every time. Well hidden.....Even if you open the ashtray it looks like a cigarette lighter.
rest of the ignition pictures here
http://www.alaskavictorian.com/jared/ignitionswitch/
I have a stock ignition switch coming but this works so well I am not sure if I wan't to even take apart my stearing collumn.
pico
1987 porsche 944
Old 01-16-2004, 09:49 PM
