-   -   944 injector part (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/14349-944-injector-part.html)
pearldrum 09-04-2001 05:03 PM
944 injector part
ok, in the seal kit, for the fuel injection system does anyone know if the pental caps come in it, they are a little cap that is in the cylander, and go around the tip of the injector when it is in postition the seal set number is 944-110-901-00
jseel 09-04-2001 06:23 PM
the part number for the caps is 928 110 90 400 (you need four obviously) plus you need the other part you listed. these apply to my 86 951, im not sure if its for anything else. i tried the caps they give you and they are to tall. the n/a caps are the proper height but they have a smaller hole. i tried to make some work by drilling them out but they fell off when i removed the fuel rail to put the proper part in. the car ran very poorly also. i havent run it with the new caps because i have the header off, saving for a new one.
