fast924S's Avatar
Send a message via AIM to fast924S
EGT install
How hard and what is involved in installing a EGT gauge. How much do kits go for? where in the exhaust is th best place to install the sensor?
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 03-24-2004, 02:45 PM
ae1969's Avatar
Send a message via ICQ to ae1969
The kits are around 100-300 bucks.... depending on what you get...
In an ideal situation you would have 4 egt's to monitor all 4 cylinders....but on the turbos #4 seems to be the most common spot.
NOrmally as close to the exhaust side on the head as possible.
Two inches away would do the trick. You drill a bung into your header.....
On a turbo you will see ~1500F at WOT. I am not sure what an NA would register to be honest?
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 03-24-2004, 04:42 PM
Send a message via AIM to Trevor
Are you wanting to set your fuel mixture manually or something?
I'm clueless.
1987 Black/Black (sold)
96' Jetta (RIP)
1986 N/A (Sold)
2001 Taurus noooooooooooooo!
1993 325is
Old 03-24-2004, 05:13 PM
TNT25169's Avatar
Send a message via AIM to TNT25169
fast924s, have you gotten your tranny fixed yet? It's been broke for quite some time now if I remember correctly....several months? Just curious.
-1988 Black 944 w/ yellow koni's, coilovers with 250lb springs, adjustable camber plates, strut tower brace, weltmeister front and rear sway bars, 968 caster blocks and 5 pt harnesses
www.apartabove.com
Old 03-24-2004, 05:29 PM
fast924S's Avatar
Its been broken for almost a year now. But in the past couple of weeks I have gotten a parts 944 and I am currently in the process of installing the tranny, its 89% installed, I just keep running out of time or I have to go do something else. Also I have some bugs I need to work on, First is find out what to do about my 17/7.5 inch wheels... they rub so Im thinking about doing a GT conversion. The rest is just little BS stuff.
As for the EGT sensor, I just wanted to know how it was done, Also I might use this idea when I install a nitrous kit but not sure yet
Old 03-25-2004, 02:53 PM
