will944's Avatar
Send a message via AIM to will944
Wolf1, Ronin, FRWilk, ae1969, Socal, robm-951 & others....
I know all you guys have 951s....except for SoCal...but he knows pretty much everything.....anyway, I need your help.
I failed emissions and realized it's bcz of the Huntley Racing chips installed. I have the factory chips...but can't figure out which is the DME chip and which is the KLR.
Part numbers on them are 1267355235 and 1267355138. Does anyone know how I can tell them apart so I can reinstall and go back through emissions?
Hope you all can help or lead me in the right direction
10 E92 M3
13 Jeep GC Limited
98 Jeep Cherokee
87 951
C3 Stingray
Old 01-13-2004, 12:51 PM
SoCal Driver's Avatar
"except for SoCal...but he knows pretty much everything"
The proper way to express this is; "I know two sentences about everything!"
Guess you can't call Huntly on this now. Kaput! So much for turbo charging NA's!
Need the imput of Doctor DME on this.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 01-13-2004, 01:13 PM
will944's Avatar
I have tracked down a Motronic DME that is the same Part Number as mine....it's at a local shop in Boulder.
So, I should be able to open up the other and find out from there....right??
10 E92 M3
13 Jeep GC Limited
98 Jeep Cherokee
87 951
C3 Stingray
Old 01-13-2004, 04:08 PM
Should.
Old 01-13-2004, 04:29 PM
ae1969's Avatar
Send a message via ICQ to ae1969
DME: 1267355235
KRL: 1267355138
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 01-13-2004, 05:37 PM
ae1969's Avatar
Oh forgot to ask.....
You dont have a signal massager hooked up to this do you? ARC2 etc...
and you are still using the stock AFM?
Old 01-13-2004, 05:39 PM
Wolf1's Avatar
You will want to make sure you are at stock fuel pressure and boost levels as well......
75 914 - Undecided.
80 931 - Gone, but not forgotten.
72 914 - old toy- sold.
And a whole bunch of German scrap metal shaped like 924's.
Old enough to know better, and stupid enough to do it anyway!
Old 01-13-2004, 05:46 PM
will944's Avatar
ae1969...thanks a ton for the numbers...they are exactly what I have!! You just made my day
Stock AFM...chips, boost controller and wastegate are the only mods I know of on the car....formerly Scott R's car.
Thanks a ton guys
10 E92 M3
13 Jeep GC Limited
98 Jeep Cherokee
87 951
C3 Stingray
Old 01-13-2004, 06:21 PM
Scott R's Avatar
Will, use my cell number if you still have it. Otherwise I can call you on the weekend when I get back in town.
I still think you may want to lean the AFM out a notch just to make sure get through.
Also I would dial the boost down pretty far so those Envirotest idiots don't overboost it on the dyno.
2018 Q5 Hybrid
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 01-14-2004, 06:34 PM
will944's Avatar
Sounds good to me
How do I adjust the AFM? Looks to be an adjustment knob on the lower right corner when looking at it. Which way would I turn it and does it "click" or should I do a quarter turn or something.
Also, I haven't played with the boost controller. I assume by dialing the boost down I wold have to turn the knob inward to close it?
Thanks for the input Scott. I was going to do it this morning...but I mine as well wait til tomorrow if I can get these things done.
10 E92 M3
13 Jeep GC Limited
98 Jeep Cherokee
87 951
C3 Stingray
Old 01-15-2004, 06:19 AM
Scott R's Avatar
I'll ask here for a second opinion but you should move the dial clockwise like two clicks to tighten the pring and lean the mix out.
All you have to do is slide the black cover off the AFM to do it. However you will probably pass just fine with the stock chips in.
2018 Q5 Hybrid
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 01-15-2004, 07:27 AM
will944's Avatar
Well I'm gonna go for it.
If I don't pass, I will call you this weekend Scott and talk to you about the AFM adjustments etc.
Wish me Luck
10 E92 M3
13 Jeep GC Limited
98 Jeep Cherokee
87 951
C3 Stingray
Old 01-16-2004, 06:26 AM
will944's Avatar
Holy *****....I passed this morning
HC limit is 20....first test the car read 46!! Stock chips and oil change....12!!!
Woohooooo
10 E92 M3
13 Jeep GC Limited
98 Jeep Cherokee
87 951
C3 Stingray
Old 01-16-2004, 08:37 AM
ae1969's Avatar
....well wasn't that fun.
Old 01-16-2004, 08:51 AM
Scott R's Avatar
LOL, don't loose those stock chips!
2018 Q5 Hybrid
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 01-16-2004, 08:55 AM
now will he tell us the performance is exactly the same ?
Tom
Early '85 944
Old 01-16-2004, 09:31 AM
Scott R's Avatar
Doubt it since the chips elimate the over boost protection.
2018 Q5 Hybrid
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 01-16-2004, 10:07 AM
will944's Avatar
With the chips the boost feels like it pulls harder...and at low boost I can definitely feel more power from the increased level of fuel....
Nothing huge...but you can feel it
10 E92 M3
13 Jeep GC Limited
98 Jeep Cherokee
87 951
C3 Stingray
Old 01-16-2004, 12:10 PM
