PorscheJeff95
pop up headlights
Hi, new 944 owner. what's the deal with the pop up headlights? I was told they do not work in my car. My first try with them I clean the connections, lube the pivot joints and push in the relay....wala! ....they work. But they never moved again after that.......faulty relay? bad connections? pivots worn? Is this a common issue? what's the fix? thanks Porschejeff95
Old 08-24-2007, 03:45 AM
924RACR's Avatar
Weak (loose) connection at the relay or the headlight motor plug. Sometimes, if you're careful, you can tweak the female end of the connector, tighten it up and get it happy again.
Vaughan Scott
http://www.vaughanscott.com
http://www.924.org
Old 08-24-2007, 05:28 AM
