KLR KLR is offline
KLR's Avatar
Tightening the Door Strap Holder?
On my passenger side door, the "strap" that has the detents and keeps the door from flinging too far open has become loose. Specifically, the bottom bolt on the piece that holds it to the car (not the door), which is held in by two cheese-head bolts, is not tight. When I try to tighten this bolt, it just spins and spins.
Is it stripped? Has anyone encountered this problem and found a solution? I suppose that I could live with it this way indefinitely, but it is annoying when openning the door (i.e., it hangs up on the detent and requires a healthy shove to open fully).
1987 951 - Stone Gray / Burgundy
15psi Guru Chips, Reliaboost, 3-bar FPR, KW Variant 3 Suspension, OE Euro Driving Lights, Iceshark Wiring Kit
Old 01-16-2004, 01:45 PM
I replaced the drivers side strap on my car last week. I'll bet the theaded part in the door is spinning. I can't see how the threads could be stripped. But how would you get back behind that body panel to see?
Lark
Ealrly na '85 944 - Manual Mahogany
'98 Lincoln MKVIII LSC
'77 Ford F-100
Old 01-16-2004, 04:51 PM
bearone2's Avatar
with x-ray vision of course.
87 951, K27/6, Almond Beige, 17" Turbotwist
87 944S, alpine white, 5sp died a violent death
84 944, silver/brown, auto, gone but not forgotten
"may the force be with you"
Old 01-16-2004, 07:58 PM
entertaining the idea
UconnTim97's Avatar
Anyway to get a stripped bolt out. I need to peplace the one on my passenger side, and the cheese head bolt was stripped by the PO
There are some who call me... 'Tim'.
a well set-up 1983 Guards Red 944
Old 01-16-2004, 08:24 PM
KLR KLR is offline
KLR's Avatar
I think that larkstar's got it right -- it feels like the threaded part behind the panel has come loose rather than the threading having stripped.
Has anyone found a solution to this problem? If I take the interior kick panel off (e.g., carpeting, etc. in front of the door) can I gain access to this area?
Old 01-18-2004, 11:04 AM
