Post do you have a FORD a/c clutch?
my '87 944na has a (broken) ford A/C clutch.
why in the world does an '87 944na have a ford part on it?
the engineering number for the rotor is
FOCH-19d786-AA
and for the pulley its
FOCH-19D784-BA
does anyone know how to convert that to a partn number so i can order a new one?
Old 09-06-2001, 07:48 AM
mideastmafia's Avatar
Send a message via AIM to mideastmafia
Post
i know that alot of parts from BOSCH are from Fords. maybe a similarity.
SHAUN
Old 09-06-2001, 10:10 AM
Bob's944's Avatar
Send a message via AIM to Bob's944
The catalog that I have list the same compressor for 1985.5 944's thru 1992 968's and the same compressor clutch for 1985.5-1995's. all nippondenso.... maybe yours has been converted to a better rotary compressor??
Old 09-06-2001, 10:38 AM
Post
nope, its stamped with "DENSO" also, so i think i was mistaken. I think its the OEM.
How do I know if i should replace the whole compressor, or just the clutch?
Old 09-10-2001, 11:05 AM
Bob's944's Avatar
mine blows cold for a few minutes before the clutch causes the heater fuse to blow. Since it's blowing cold, the compressor is working. Hopefully you have a similar problem, cause replacing the compressor leaves you at the will of the shop that gets to evacuate and recharge (i've found alot of rip off artists doing that)
Old 09-10-2001, 11:15 AM
Post
I suspect you have the same problem as I. The coil wires in the clutch have a very thin layer of insulation on them. Heat has ruined the insulation and the thing is shunting the full length of the coil wire because there is contact somewhere down in the coil. Because the path is shorter, there is less resistance. Therefore it will blow fuses. And because there is more current, there is more heat buildup further melting away the coil wire insulation. Mine drew more and more current over about a year. Now it blows the fuse (10A) in a minute or so. I'm getting another clutch.
Old 09-10-2001, 03:01 PM
Post
what about the overheating compressor problem? that can melt the insulation too, right?
Old 09-10-2001, 06:01 PM
