Question Tach & Speedo swap
I have an '83 944 and was thinking of swaping the postion of the speedometer with my tachometer, which would place the latter in the center. Has anyone here tried this? Is their any reason why this wouldn't work?
Old 09-15-2001, 06:00 PM
lm6y's Avatar
Post
I might be wrong, it's been awhile since I've had mine apart. I think the wiring will not reach in the transposed positions though.
Old 09-15-2001, 08:00 PM
951carter's Avatar
Post
it will work, i have done it. you have to make some slack in the speedo cable though.
Old 09-15-2001, 08:14 PM
Thumbs up
951carter
How much slack are you talking about and how did you go about doing it? Also, did you have to remove your steering wheel to get the
instrument panel off?
Thanks.
Old 09-15-2001, 08:37 PM
