Timing
hey does anyone know how to set the timing on an 86 944? The car idls fine but when I drive it it shakes like crazy and the mech said he thought it was out of time. The haynes manual doesnt mention it that I can find.
Mark |
check the motor mounts before you go messing with the timing. what you are describing is typical of bad motor mounts.
Your mechanic, does he have prior 944 experience? |
When last were the Timing and balance shaft belts looked at ? Balance shafts out of sync!
Mark '86 944NA |
to me shaking indicates wheel imbalance/suspension problems.
http://home.pacbell.net/nirky/turbo_120usa.jpg |
Do a search on "Balance Shaft" and on "vibration". This topic has come up several times.
Mark '86 944NA |
| All times are GMT -8. The time now is 08:03 PM. |
