adrian jaye's Avatar
Post clutch master cylinder
Hi Guy's the saga continues....
as a thought how can you check if there is air in the system. without getting under the car to actually bleed the system
cheers
Old 09-19-2001, 06:50 AM
3sonfather's Avatar
Post
What are your symptoms and what were the events leading to your concern?
If your clutch pedal stays down you could have air in the system, but more than likely if you haven't tampered with the system, you'll need to replace the master, slave or both.
Scott
Old 09-19-2001, 07:25 AM
