When it rains, my driver side (in the front) gets wet, pretty wet. Can anyone give me a hint of where the problem could be?
I've looked around but could find where the water come from. Thanks Eugene |
Use the old hose trick. Run water over the sunroof seal, and the rear hatch laminate seal, and around the windsheild. You'll find it!
mine does the same i get a puddle in the drivers side back floor carpet and water seems to collect on the lower sill
when i open the door it all pours out from the bottom door sill??? |
There is a water drain hole near the left hood strut, otboard of the fuse panel, that gets plugged up it, water puddles and seep into the drivers side foot well.
