Question tin cans in the back
I started getting banging tin can sounds coming from the rear end 2 days ago.
It is more noticable when there is torque on the rear wheels like under acceleration or decelaration.
It is hardly noticable when cruising (maintaining speed) at any speed.
Sometimes it dissappears for 10-15 minutes, and then magically it reappears.
This happened for 2-3 days last spring and then totally dissappeared until this week.
I suspect a half shaft but wondered if anyone else has experienced this.
early 85 944 na
My water cooled flat six is in my motorcycle...
Old 01-14-2004, 08:17 AM
adrian jaye's Avatar
torque tube ???
have you checked and replaced the tranny oil ?
The fear of God is the begining of wisdom <><
NotJustPorsche
Subscribe: notjustporsche-subscribe@yahoogroups.com
Old 01-14-2004, 08:23 AM
SoCal Driver's Avatar
CAT breaking up? Loose heat shield? Old beer cans?
CV joints can make a clattering sound under load.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 01-14-2004, 08:29 AM
..P ..P is offline
A cat breaking up can most certainly sound like a tin can banging around, even with the car sitting still and just revving up through the harmonic band to cause the rattle.
P
1983 928S 5-speed, 1984 944, 1990 944S2 Cabriolet
My other car is a Chris Craft Commander
http://www.chriscraftcommander.com
Old 01-14-2004, 08:30 AM
I suspect drive train problem, probably not tranny because the frequency of the thump is changed with speed. Thumps get faster as the car accelerates, slows down as I decelerate. Changing gears doesn't affect frequency.
I checked for beer cans. Found 2 bottles, but no cans...
early 85 944 na
Old 01-14-2004, 09:01 AM
Let's go shooting.
Dark Skies's Avatar
Does it sound like it's coming from the wheel end or nearer to the centre? Manual or auto trans? Thump as in dull? Does it come with a rough once per wheel revolution type clacking sensation - like a stone caught in the tyre tread?
1983 944 Lux (manual) 2.5 litre 8 valve na and no pas
1991 944 (automatic) 2.7 litre 16 valve na and pas
"I have only five words for you: From my cold, dead hands."
Old 01-14-2004, 09:06 AM
It sounds like heavy metal hitting heavy metal - but muffled, not metallic. It's hard to pinpoint the sound while driving, but it sounds like its to the right of the transaxle. It is a manual and the transaxle was replaced about 20k ago. The sound is definitely related to the speed of the axle/tire, not the transmission, but it sounds like it's slower by maybe 1 to 4 than the actual speed of the car.
early 85 944 na
Old 01-14-2004, 09:22 AM
Let's go shooting.
Dark Skies's Avatar
I'd jack up the offending side of the car, remove the wheel and see if I could feel any roughness in the area of the rotor - if there's a distinct catching sensation every revolution it might be a problem I've recently experienced - a worn stub axle causing float under the outer wheel bearing resulting in a cracked race.
Or it could be either worn CV bearings or hopefully, as with a lot of older cars, the grease having hardened and simply requiring repacking. Grab hold of the shaft and see if you can feel a lot of up and down movement - it's supposed to have some end float so don't confuse the two.
Old 01-14-2004, 09:37 AM
I wondered about the grease packing as it started when it was less than 10 degrees out. But, the last time this happened it was early summer.
early 85 944 na
Old 01-14-2004, 09:56 AM
Z-man's Avatar
Do you have any backlash in the drivetrain? If you let off the gas while the car is in gear, do you hear a clanking sound?
If so, it's most likely a drivetrain / tranny issue.
-Z-man.
2010 Cayman S - 12-2020 -
2014 MINI Cooper S Coupe - 05-17 - 05-21
1989 944S2 - 06-01 - 01-14
Carpe Viam.
Old 01-14-2004, 11:31 AM
Wheel bearings. Cracked race. Most likely the inner race to the roller bearing. This is the outside bearing on the stub axle. The inner bearing is a ball bearing. Takes up the lateral loads. The outer roller bearing takes up the vertical load.
CV's can clunk too. Find an empty parking lot, roll down both windows and make tight right and left turns. You will hear more noise one way than the other.
Old 01-14-2004, 11:36 AM
just replaced the right halfshaft. that did it. thanks for everyone's feedback.
early 85 944 na
Old 02-03-2004, 02:59 PM
Save your money. Most likely you will have to do the left one in a few months.
Old 02-03-2004, 04:42 PM
drivers side was done when new transaxle was replaced last February. This one is supposedly rebuilt with Lobro parts so it should hold up. Other one was a rebuild and it's been fine so far...
early 85 944 na
Old 02-03-2004, 04:55 PM
