Scott R's Avatar
Post AFM Adjust/Emissions Failure
Hey guys! Well I failed my emissions test today with high CO. State limit is 20 I blew a 40.30. So I need to get the CO down. I will replace the O2 sensor, and then I will also surely need to adjust the AFM. So, the service manual states that leaner is "Anticolockwise." Is standing in front of the car or looking from the passenger compartment? I guess I mean to ask, is it screw out for lean or screw in?
87 951.
Old 09-28-2001, 06:57 AM
Cool
If the AFM screw was never messed with replacing the O2 sensor is probably all you have to do. The screw only changes the mixture at idle.
Screw in - richer
Screw out - leaner
How is the CAT? With a rich or slightly rich mixture there should be a little sulfer or rotten egg smell when the car is driven hard.
Mark
'86 944NA
[This message has been edited by mlue (edited 09-28-2001).]
Old 09-28-2001, 07:44 AM
Scott R's Avatar
Post
Yes it has been messed with. The cover has been drilled. Any rule of thumb on how many turns is normal?
Old 09-28-2001, 08:13 AM
Post
Checked the air filter?
Old 09-29-2001, 03:32 PM
Cool
Check out this Post:
http://www.pelicanparts.com/ultimate/Forum5/HTML/004383.html
I had to adjust my screw because the PO had messed with it as well. It may not be perfect but its in the ball park.
Mark
'86 944NA
Old 09-29-2001, 04:44 PM
