quick supension/option codes question
One of my option codes is ?65 (i forget the first digit), listed by Peter Morgan as "sport shocks and stabilisers". I know that "stabilisers" in this context means "sway bars," and I know that I have the 14mm stock rear sway bar... but do I also have a front sway bar? If so, what diameter?
Yes all 944s came with a front swaybar.
I'm pretty sure it is a 23mm, but to be sure you could always get under there with a micrometer. |
On my 944S2, Option code 474 was the "Sport shock absorbers." AFAIK, it included Koni Yellow Adjustable shocks, and firmer springs (around 180lbs or so).
HTH, -Z-man. |
| All times are GMT -8. The time now is 07:58 AM. |
