TCMdocs944's Avatar
Red face Leaky injector - Yes I searched
Ok, so I search the historical documents and have an injector leak question still.
Injector closest to the front is leaking from the bottom seal closest to the cam housing.
..I changed all seals 2 months ago.
Did I just not do that one properly or is the hold-down bracket possibly bent....
Happen to you before?
Think I just need to remove and recheck the seals?
Any other Ideas?
BTW- fuel leaks only when the rail is pressurized and only slightly..
BTWBTW- not driving until fixed
83 944 white w/Boxster wheels
Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
Old 02-02-2004, 03:05 PM
AFJuvat's Avatar
Could be a bad seal, or the injector was not seated all the way in.
Fortunately, seals are cheap - something like $5 each
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 02-02-2004, 04:07 PM
TCMdocs944's Avatar
I have an extra seal kit...will pull and try.
Not seated all the way is what I am thinking but that injector is right at the end of the rail where it connects to the head....thats why I am thinking I might have slightly bent something..
Maybe I will remove the rail and try reseating it first.
Old 02-02-2004, 04:12 PM
ilikemy944's Avatar
Send a message via AIM to ilikemy944
Mine is doing this, or was, until today.
Replaced seals at least 3 times...
New injector no leak Hope seals works for you.
Brad Tompkins
Current: '86 951 Sunroof Delete - '89 951 - '83 944 Spec - '08 Cayenne Turbo
Past: '88 924S Track - '86 944 16v - '87 951 - '87 951 - '88 951S - '08 Cayman S - '87 944 Track - '93 968
Old 02-02-2004, 04:13 PM
Make sure and lube the o-rings (i use some ATF) so they don't get cut-up when slipping into the manifold & fuel rail.
Rob
Old 02-02-2004, 06:41 PM
SoCal Driver's Avatar
There is no fuel pressure at the injector seal into the intake manifold. As far as the intake seal is concerned you can use an old rubber band if it seals off the vacuum.
If there is any evidence of fuel on the outer part of the injector AND it can not be traced back to the upper seal; the injector has ruptured. Replace it.
Not so for the upper seal. This sees all of the fuel rail pressure. Use compressed air to blow off the injector to see where the fuel is coming from.
Most fuel rail leaks can be traced to a fracture at the mounting bracket welds.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 02-02-2004, 09:11 PM
