bad heater behavior
I seem to have the opposite heater problem from what I've read.
My heater works great as long as I am stopped or moving at low speeds - like driving around town.
But, on the open road, above 45-50 mph, the heat quickly moves to cool and the gauge moves to the bottom side of the low range.
This also has a effect on the defroster's ability to keep snow and ice clear on the windshield.
early 85 944 na
My water cooled flat six is in my motorcycle...
Old 02-03-2004, 01:53 PM
1.2gees's Avatar
Send a message via AIM to 1.2gees
Sounds like a thermostat that's getting stuck open, or improperly installed (or missing, or whatever, in short a thermostat problem). You could have a timing belt that's too loose, or a waterpump that's on it's way out as well as a low temp or defective thermostat, but that's less likely.
Ahmet
Cheers!
Old 02-03-2004, 02:03 PM
Just had timing belt, water pump, radiator and thermostat replace about 8 months ago. Thermostats can go bad, but it seems to work fine when moving around town. In fact if you idle for 3-5 minutes, you get too hot. It seems that as cold (it's been under 25 for about a month) air blows past the radiator, the temp drops. As soon as you slow down to 30-35 it warms right back up.
early 85 944 na
Old 02-03-2004, 02:32 PM
SoCal Driver's Avatar
Thermostat. Stuck or missing. These cars were designed by Germans who have cold winters.
Then your heater valve may not be opening completely if the cable sheath to it is loose at either end.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 02-03-2004, 03:40 PM
would you take it to regular mechanic or p-car specialist?
early 85 944 na
Old 02-03-2004, 03:56 PM
Well, I would fix it myself.
After being a mechanic to work my way through some college I don't trust most of them.
Old 02-03-2004, 05:36 PM
I hear ya... but it's 17 degrees with 4 inches of frozen snow in my driveway.....
early 85 944 na
Old 02-03-2004, 05:40 PM
Guess it might be better at a mechanic that is familiar with the cars.
Possibly cheaper than heating the garage.
Been raining here. Reall cold. Low 50's.
Old 02-03-2004, 05:43 PM
Verruckt's Avatar
Thermostat! Exact same problem happened with my BMW. Thermostat cured it in 20 minutes. Of course it takes a little longer to get to the thermostat on a 944...
On a smug note: I haven't used my heater in 16 months, thanks to Uncle Sam. Military service in the tropics, not to bad.
The crashes people remember, but drivers remember the near misses. Mario Andretti
1991 944S2 Rally #951 Rally-America.com
Old 02-03-2004, 06:07 PM
Hah!
My dad was on his way to the invasion of Japan. The war ended when he was in Hawaii for training.
An officer was going over the personal files and found he could fix radios. He had him come to the back of a jeep and threw back a tarp. There was a five tube receiver just beat to heck. Asked him if he could fix it. Dad said possibly after he straightens it out.
So for the next 18 month he fixed and few radio controlled target drones and partied with the officers daughters on the beach! Didn't have a 944 but then who would care!
Old 02-03-2004, 06:46 PM
We're in a heat wave, got up to 28 this morning and I had so much heat I had to turn the heat fan control down - 1st time in a month. It seems that somewhere around 20 degrees or so is where it either has heat or doesn't...
early 85 944 na
Old 02-04-2004, 06:17 AM
