How fast are you going...
Recently bought a 1984 944 - I question the accuracy of the speedo - so before I ge ta ticket... how fast are you traveling at 2900 rpm in 5th? Tried to have son pace me in the Explorer - he's not so good at that yet....so I turn to you all....
Thanks |
For me 3000 in 5th is about 80 mph.
When I first got my 83 I noticed that It felt like I was going smooth and slow but the speedo said 70mph.
Came to find out the speedo is right on. These cars are really made for cruising at speed. The fun comes when you go to pass someone...3000-5000rpms is soooooo sweet. Hope that is the case with your speedo...good luck. |
70mph at 3k in 5th
Of course in an early 944 (before late '85) the speedo is driven by the front left hub, so it's only accuarate if you have the stock size tires (215/60/15s?).
Hence, you need larger tires all around...
this is only by memory, but if i remember correctly in 4th gear
2K rpm = 40ish 3K rpm = 60-65ish 4K = 85ish correct me if i'm wrong; my speedo cable snapped awhile ago, so I have been going by these tach estimates for about 2 years :) |
Tire size does matter. I just recently switched from 225/60 15s to 225/50 15s and I can tell the difference. The tire size of the 225/50 are 1 inch shorted in diameter than the 225/60s and there is about a 7 inch difference (smaller) overall circumference in the tire.
So at 3K rpm in 5th with the 225/60s I was doing about 76 MPH. With the 225/50s the speed is about 72MPH. I have taken into account the difference in the front tire on my 83 for these speed comparisons. The benefit is that the car is quicker off the line and handles a bit better with the car lower the ― inch The downside is that the rpms are running higher that I would want and I use some extra gas. I now need to run up on 2X4s to get my jack under the car. I'm thinking about getting 225/60s for the back and keeping the 225/50 for the front for distance driving. My 2 cents. |
CJF, Have you been pulled over much without a speedo? We drove down to Texas in a blazer without a speedo, but I doubt that thing would've gone much over 65, so I think we were okay :)
edit: my speedo is off 5 mph at 60... so when it says 60 I'm really going 65. I've been pulled over and given warnings five times now. |
You're fortunate to just get the warnings.
Most of the time they'll say "you drive a porsche, im sure you can afford the ticket".
Rob 83
You told us how fast you were running but which tires gave the correct speed. I am thinking of 225/60's rear and 225/50's front. |
I cant tell :(
My speedo says im going 184 kmph (115)...but i kept it to the FLOOR..and the car wasnt accelerating at ALL :( I wont rest till i hit 300. |
Borrow a friends GPS unit. Everyone has one. Do the comparison yourself. Will need to be on the dashboard to get a sky view.
184 kmh and no accelerating (flat road I assume) is not good....car must go to 200 at least
but check the manuals,gear and speed ratios are there. |
"CJF, Have you been pulled over much without a speedo?"
Nope. Got pulled over once in the Porsche - Christmas eve 2000. Doing 70-ish in a 40. $400 ticket, misdemeanor speeding. It got thrown out, and I only had to pay a $100 fine. I have probably been pulled over about 10 times between getting my license in 1996 and that ticket in 2000, but haven't been since. I still drive fast, but seem to know when to take it slow; I drive smarter, not harder. |
Rob 83944-
I am thinking of putting 225 60 15's all around. Did you like your car with this set up? Do you have any pictures you could post? thanks or just send em to me seidelha@grinnell.edu |
Used brother's GPS to solve the mystery of the inflating speedometer.....Mystery solved 2900 rpm=80 indictaed= 77 actual, stock tire size on 1984 944
An easy way to check your speedometer is to get on a road with mile markers (like and interstate and some primary roads) and drive with your speedometer showing 60 MPH. It should take you exactly one minute to go one mile.
You can also check the accuracy at other speeds, you'll ust need to to the math. |
"I am thinking of putting 225 60 15's all around."
I thought about this too, but I think I will do 215/60/15 in the front to keep the speedo accurate (if I ever replace the wire) and the steering from getting heavy (no power steering here), and then 225/60/15s in the back. Has anyone run this setup? |
I had 205/60/15s front and 235/65/15s in the rear. It definately gave the car an agressive look (lower in the front, big tires in the back, very Old School). Unfortunatley it meant I was always beating up the front spoiler, the speed was off, and I'm sure it caused more stress on the drivetrain to spin up the rears. I just went back to stock all around, and I can really feel and see the difference.
The best way to measure the accuracy of the speedometer is to go a known distance ( 3-5 miles is ideal) and check to see how far the odometer changed. Just a simple math calculation to see how far your speedometer is off (it at all) then. We always do this when different tires are put on the cars. Changing tires is just as good as swapping gears, but messes with your speedometer.
HHmmmm
CJf - I think I like the 225r 215 front idea. Nobody with pics? Right now mine has 215's all around and really needs tires bad. Ok, Ok......PICS! If anyone has them don't be shy. 225's all around? 225r 215f ? |
For those of you who donīt have the manual,this would help a bit...gear ratios
Pre 85 http://forums.pelicanparts.com/uploa...1076024339.jpg Post 85 http://forums.pelicanparts.com/uploa...1076024984.jpg |
First - up to 50
Second - 80 Third - 120 Fourth - 160 Fifth - 210 K..im gonna try shifting at these RPMs when i get the car on the road.. |
I found this speed/gear ratio Excel spread sheet on the www.924.org site under downloads. It gives speed based on tire size and rpm. For the 944, look in the 944 column.
If you have Excel, you can enter your tire size, 225, 215, etc, tire ration 60, 50, ect and then enter rpm and it will calculate the speed in gears. http://www.924.org/Downloads/PorscheTrans1.xls The closest speed to OEM tires for the 83 944 (215/60 X 15) was 225/50 x 15 at 3000 RPM in 5th. 80 MPH (215/6- x 15) vs 81 MPH (225/60 x 15). I am losing about 5 MPH at 3000 rpm using the 225/50 x 15 tires in 5th gear. |
Mt speedo actually doesn't work.
I use a GPS thats VERY accurate. If you know someone that has a GPS that youy can borrow, that would be the way to go top check the accuracy of the speedo. I have found that ALL speedos are inaccurate. Below 35 MPH they are off 5% (fast) , above 40 off 1-2% (slow). Just my opinion |
Something's not right...
I have a 1983 944. On my way home tonight..i was doing 120 MPH at approximately 4300 RPM....now when i look at the chart...those 2 figures are NOWHERE close to each other... I dont know which one is off..my tach or my speedo.. But i hit 120 before..i know what it feels like..and i was definetly cruising at that speed.. Also...i found that if i completely floor it...the car actually goes SLOWER than let's say...3/4 throttle |
Do you have the same final drive ratio as the charts?
Manute...your charts confuse the hell out of me..
Are you sure this isnt for the 944 Turbo? Cause my car by comparion is NOTHING like those charts :| |
No,they areīnt from the turbo,i downloaded the n/a manuals just for curiosity;are you sure you didnīt made wrong the conversion of kmh/mph?
As seen there,5th gear 6000 rpm means about 220 kmh, the turbo chart says about 250 kmh at the same rpm. Maybe euro specs are different,but I donīt think so,referring to the gearbox.Gear ratios are fixed,if car is stock (and tires),speed and rpm must be like in the chart...Iīm confused too, īcause it seems like each one has itīs own ratios here... |
First - up to 31 Second - 50 Third - 75 Fourth - 100 Fifth - 130 |
those charts are from owner's manuals so if there is one in your glovebox, look in index
| All times are GMT -8. The time now is 12:21 AM. |
