Gon fix it with me hammer
svandamme's Avatar
Angry Old Cranky does it again
today i wanted to prep the car for technical checkup to be road legal... the last months i spent fixing things and it looked as if i was getting on top of the ****...starting cold and hot are fine.. everything else seems to work...all i need is brake adjustment and tightening the belt....
when i almost arrive at the shop, poooof white smoke
the water hose that attaches to the cabin heater system had failed...
easy to fix, reattach hose... next
next on the list , tighten the belt... done
readjust rear brakes...done
replace the right front light hose, the small one that doesn't go in and out... done wait , now the high beam on the left one doesn't work no more... @#$@#
check wires, no voltage... notice a little wire going to the right headlight.. busted ...
new wire.. done.. not so it twists in the headlight raising assembly.. shorts out the electrics..
back to square one.. new wires , connectors . headlights work...
when i think i'm done... not so reverse gear light is out.. and fuse 9 keeps shorting out...haynes manual proves useless once again since fuse 9 is supposed to be the brakelights and the direction indicators...and those actually work.
gave up , drove home... got in traffic jam... guess what..
fan is out too...running hot ...
starting to think that Old Cranky is jinxed and is wilfully trying to piss me off because it's jealeous of the 911 beeing restored from the chassis up...
tomorrow another attempt to please the green machine...
Stijn Vandamme
EX911STARGA73EX92477EX94484EX944S88NOW987C2007
Old 02-05-2004, 12:03 PM
TCMdocs944's Avatar
You tempted the Gods....
Or somehow pissed her off.
Good luck on your next "date".
83 944 white w/Boxster wheels
Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
Old 02-05-2004, 12:23 PM
svandamme's Avatar
it runs in the family...
Stijn Vandamme
Old 02-05-2004, 12:42 PM
TCMdocs944's Avatar
Hee he,,,,that car reminds me of "Herbi goes to _____" can't remember where...
....I thought that was the cooolest when I was a kid!
Old 02-05-2004, 01:26 PM
svandamme's Avatar
that one actually was in one of the movies
it was one of the stunt herbies
and guess what, it has a 911 engine
Stijn Vandamme
Old 02-05-2004, 01:44 PM
ae1969's Avatar
Send a message via ICQ to ae1969
Originally posted by svandamme
............ and guess what, it has a 911 engine
NO FRIGGIN WAY............
LOLOLOL
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 02-05-2004, 01:48 PM
TCMdocs944's Avatar
Someone needs to post that on the 911 boards.....just to stir the pot a little!
Old 02-05-2004, 01:53 PM
svandamme's Avatar
i'm not bothered, i have both the 911 and the VW waterpumper porsche and i like em both... i'm not ashamed of the fact that a bug is basically a Porsche, and VW ag is family of Porsche ag
EDIT... and i probably will get myself a bug sooner or later...
if i'll wack a 911 engine in it will depend on what i want to do with the bug...
if for practical use , not ,
anything else flat six transplant....
Stijn Vandamme
Old 02-05-2004, 02:11 PM
svandamme's Avatar
correction , the above bug doesn't have a 911 engine, it's a 356 engine
full story :
http://www.clubvw.org.au/herbie_no%202.htm
Stijn Vandamme
Old 02-05-2004, 02:17 PM
svandamme's Avatar
cooling problem sorted out > forgot to bleed the cooling system , had some air left in it ...
the short cirtuit is kind sorted > the reverse gear light and the horn are on the same fuse ..
horn relay removal > still shorts the fuse
remove the reverse switch from the tranny > still shorts
>> there's a wire that connects to two of the contacts of the horn relay >
cut that wire > fuse doesn't burn out anymore
slight problem > need to get a technical check to get the cars papers sorted.. but the horn is part of the deal...
finding the short is a needle in the haystack
i might just create a whole new circuit for the horn....
the only thing that worries me now is :
if i fix the horn > what will break then?!?!?!
past expierience is that for every thingie i fix , something will break withing 12 hours or less...
oh yeah .. got a ticket today because i didn't have the tech-check certification ... and the reason why they stopped me ??
the cops thought that the smaller lights below the headlights are foglights
,and foglights are a no-no when there is no fog...
interesting forcast .. evertime a cop sees me in the dark , i'm going to get pulled over , because they think those are foglights when in fact i don't have foglights at all, front or rear.. and i can't disconnect those lights or i fail the tech checkup
i seem to pick my cars just as i pick my women :
high maintenance , and no chance of getting peace of mind ...
i should get me a Toyota Hi-Lux and a peasant girl instead
Stijn Vandamme
Old 02-06-2004, 02:49 PM
svandamme's Avatar
update,
monday, she passed the APK tech test, and is road legal now...
i was very happy, for a bout 6 hours... then i noticed smoke
mildly , couldn't see where it came from , it wasn't much
today i found it , oil dripping on the exhaust,
looks like i'll be replacing the head gasket this weekend
by the time i got to the shop, a new development :
all of the sudden , i park, checkout some things, wanna drive a bit...got a knock somewhere, speed related, not engine...
not identified yet, but hey , why not ... i've always wanted to replace bearings/axles sometime in my life...
good thing is , the 911 is ready for the welder/paintshop , with some luck that one will be ready for action soon, and the weather will clear up...i should get myself a different hobby, shuffle board looks good, little room for technical gremlins...
Stijn Vandamme
Old 02-25-2004, 10:57 AM
SoCal Driver's Avatar
Cam cover gasket. Not head.
Oops a 924. Well never mind!
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 02-25-2004, 11:02 AM
Dude..from this entire thread..i read it all...you hate the 924..and honest to god..from reading all that..i hate it too!
So dump it, it's a piece. Done and done.
Old 02-25-2004, 11:04 AM
svandamme's Avatar
yeah , i would if i could , i do want to .. .but the thing is ,
i've pissed my money away buying and restoring a 911
this 924 was just intended to be my simple get me from A to B during winter time car... by now i've spend my money on the 924, and if i sell it ( read , dump it to a parts stripper ) i'll basically get enough money to pay for a second hand scooter...
which still would be crap in cold weather...
might as well bite the bullit and fix the car... and maybe be dry till springtime911time
Stijn Vandamme
Old 02-25-2004, 11:23 AM
svandamme's Avatar
parts are relatively cheap, it's more time and inconvenience...than money... and no i don't hate the green one, i like it when it runs...
but it's a frustrating thing to suspect your car is jinxed
Stijn Vandamme
Old 02-25-2004, 11:25 AM
TCMdocs944's Avatar
Exorcism
Voodoo ritual
Check under the seats for potions or spells
Maybe just go do something nice for her - professional detailing or something.
BTW- congrats on getting it sorted
Old 02-25-2004, 01:36 PM
svandamme's Avatar
i already looked into the chicken and goat sacrifice thing , but it would ruin my interior
Stijn Vandamme
Old 02-25-2004, 01:37 PM
svandamme's Avatar
needless update on this
she behaved for about a month now, it's are record ( i'll overlook the minor hickups like starter motor sometimes choking, since it never failed completely)
but now my fuel pump is going south
i'll be heading for the chicken farm tomorrow, to get me some birds for a new voodoo sacrifice
Stijn Vandamme
Old 04-03-2004, 11:55 AM
