Question on wheel bearing replacement
Have a 1983 944.
I have to replace the rear bearings.
I needed some help on the tech tips to do this job.
Also, I think will do the front bearings.
bshah@satx.rr.com
Old 02-06-2004, 05:28 AM
SoCal Driver's Avatar
Rear bearings just fall out compared to the front bearings. Well, front outer bearing races that is. Should use a puller on the front with the proper collets. You can drive them out but you have to be darn careful to NOT nick the bore the races seat in. Never replace just the bearings and inner races on the fronts.
The Haynes manual does a decent job of instruction.
Check out www.clarks-garage.com and www.924.org for more info. Yes the bearings on the early 944's are the same as the 924's.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 02-06-2004, 06:30 AM
Composite Shop Owner, DJ
MixMasterK's Avatar
Send a message via MSN to MixMasterK Send a message via Yahoo to MixMasterK
What is an average time for replacing the rears on an '86 944?
'86 944, 5 Speed (Daily Driver)
Old 02-06-2004, 08:48 AM
