Post Difficult cold starting cured
Finally took my '89 S2 to a trusted mechanic to diagnose a cold-start problem (car would always start eventually, but it took about four tries...embarrassing, more than anything else). Thought it might be bad injectors ($$$$$!), but it turns out it was only a bad one-way check valve in the fuel pump ($14 part). Valve was not seating, allowing fuel to drain away from the injectors and back into the tank.
Also, had gearbox refilled with synthetic lube ($36 worth), which has increased shifting smoothness and ease by a small but noticeable amount. If anyone's interested in the brand of synthetic, I'll call my mechanic back and find out.
--Doug
Old 10-04-2001, 09:48 AM
1.2gees's Avatar
Send a message via AIM to 1.2gees
Post
Wow, a checkvalve in the pump... Never heard of that failing before.
Ahmet
It's all the driver...
My page over1g@hotmail.com
Porsche owners Gallery.../My 944
Old 10-04-2001, 09:01 PM
3sonfather's Avatar
Post
Curious to know if your symptoms were just at start-up or did you notice poor performance at high rev's (max fuel demand) as well.
Thx
Old 10-05-2001, 06:04 AM
Post
No symptoms at high revs. Other than the cold-start problem, the driveability was excellent, without any flat spots. Checked with my mechanic, and he said the fuel pump is in an indentation beneath the tank, normally obscured by the tank's plastic cover. Check valve screws into fuel pump.
He also said the gearbox fill is Kendall synthetic. He's got other customers who swear by it...they also say it reduces shifting effort and makes the box feel smoother.
--Doug
[This message has been edited by Doug914 (edited 10-05-2001).]
Old 10-05-2001, 09:55 AM
Send a message via ICQ to PrerYDoG
Post
Had the same thing happen in my 86 Buick Riviera. I just replaced the whole damn fuel pump though, fixed it right up.
Old 10-05-2001, 10:56 AM
