Send a message via AIM to toolboy62 Send a message via Yahoo to toolboy62
rear fog light?
Got another question, how do I get a rear fog light for my 944? I modified the rear light clusters of my old VW Scirocco so they would work like the European cars do and added a Euro fog switch, is there a similar switch available for the 944? Believe it or not sometimes I do have to drive in semi-serious fog.
thanks,
nate
Old 02-09-2004, 01:12 AM
Manute's Avatar
My car is euro stock,so it has two fog switches,one for the front ones and another for the rear ones.So at the worse case,you could order it to a euro shop.Dont know if the conversion is troublesome.
Old 02-09-2004, 02:17 AM
entertaining the idea
UconnTim97's Avatar
I would think the same thing. They were made for European cars, so you should be able to find oneavailable.
There are some who call me... 'Tim'.
a well set-up 1983 Guards Red 944
Old 02-09-2004, 04:08 AM
The empty bulb holder in the tailinght assembly is made for the read fog, I believe...all you need in the back is the plastic bulb holder...mine are wired in as an extra set of tailinght (on all the time the lights are on) - I had to decrease wattage on the bulbd, as that lens allows a lot of light through
memories
'70 914
'80 GTI
'94 Miata
'84 944
'96 328iC
now 2001 Miata LS - also looking for 944 cabrio
Old 02-09-2004, 04:33 AM
SoCal Driver's Avatar
Yeap. Empty socket. Even an extra wire in the loom for it. Just have to find it's other end under the dash.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 02-09-2004, 06:41 AM
Official Sponsor
vital-transform's Avatar
I have been planning to install one in mine this spring ...I have additional sockets and will add a switch probably in the console near the mirror switch over, but I just got some of these hyper LEDs (ebay) that I think will work nicely without having to use any sockets at all
I plan to wire it with it's own fuse and a seperate harness that I will fabricate.
1988 - 924S Guards red, auto trans
Old 02-10-2004, 08:26 PM
