Hawktel's Avatar
Porsche Crest 944 Oil Pump project
How long does it take to change the oil pump on a 84 944?
What is the cost to do it? Anyone know the book time for this kind of project?
Thanks for the help guys.
Old 02-10-2004, 10:48 AM
ae1969's Avatar
Send a message via ICQ to ae1969
Re: 944 Oil Pump project
My first question is why do you need to replace it ... ?
and second you have to drop the oilpan to get at it......
I would find it easier dropping the engine and doing a complete overhaul........
but what happened that you have to swap it out ?
and that oil pump is 3-4 hundred bucks..... and add all the other parts you will need/want to replace on your way there.
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 02-10-2004, 12:27 PM
TCMdocs944's Avatar
I kinda have to ask the same question as AE...
The oil pump is painfully simple on the 44. A one gear jobby. Seems what "goes wrong" with it is a groove developing in the gear that mildly interfears with operation.
I "mistakenly" removed mine while in the process of a front seal job. Amazingly enough I did not damage the front oil pan seal even though I didn't drop it for the job. (BTW-NOT recommended).
If I knew the pump was bad I would do the oil pan gasket AND the front oil seals, belts, rollers if any of those things were in question. I did them all one job at a time over the past year and should have just done the whole shebang.
Answer - once the pan is dropped and the front belts/pullies/covers / crank seal is remove, the actual pump is a piece of cake
83 944 white w/Boxster wheels
Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
Old 02-10-2004, 01:22 PM
