Setting The Clock
Can anyone tell me how to do this?
Thanks in advance. GHEN |
Seriously...anyone at all, need to set my clock.
Thanks |
I have done it a million times.....but honestly have no idea how I did it.
It's just one of those things you need to mess around with to get. All I know is that one botton (left one maybe) has to be held down while you set the hour with another. |
you guys dont have an analog clock?
youre missing out :) |
my analog clock only works when the car is running. not sure why, but I'm okay with it.
Hey, my analog clock only works when the car is running too. What is up with that? I have been using my clock as a engine hour meter.
did someone wire it to the ignition circuit instead of the continuously "hot" circuit on you?
It used to work all the time, but i noticed one morning it was off by a little bit... the next day it was off a little more, then I finally realized that i just happened to stop the car and get back into it at relatively close times, and it was broken. oddness.
But for the digital clock...how do you set it?
AND Thanks Will944, but it doesn't seem to work for me. |
| All times are GMT -8. The time now is 09:00 PM. |
