Location: St. Louis - on the weekends, anyway; actually, most weekends...maybe I'm working too hard...
S2 crank in 2,7L block....?
I would like to create what the factory never did, a 3.0L 8 valve NA engine. I have the ingredients: a good 2.7L engine and an S2 crankshaft. The plan would include having the reciprocating items all balanced and lightened, perhaps with knife-edging and boat-tailing along the way. I figure the output should fall somewhere in the same range as the 2.5L 944S or better, but with superior low end torque. Questions:
What compression ratio will I end up with (I assume the S2 crank will pull the stroke range a little lower in the cylinder)?
Any possible clearance problems - and if not, will I have comfort room for a slight head shave to bump the compression?
Are the 2.7L con rods compatible with the 3.0L crank journals? I would want to use the 2.7L's rods...
Any other problems with this concept?
TIA Skip
Old 02-11-2004, 07:03 PM
Seems to be some debate on Rennlist about where the CR would end up, and whether new con rods would be needed...any ideas would be very much appreciated, as I need to buy this 3.0 crank pretty soon if at all. TIA Skip
Old 02-12-2004, 06:16 AM
I don't think the 2v pistons can be used...the 3.0L pistons (4v) are much shorter and have the wrist pin located lower than the 2.7L pistons for top and bottom clearance reasons - IIRC
Tom
Early '85 944
Old 02-12-2004, 06:25 AM
