'87 OEM 924S Radio Antenna/Headlights?
Hi folks, just signed up and have a few questions about a 1987 924s I recently purchased.
1. Is the OEM antenna a manual or power antenna? When I purchased the vehicle the antenna was missing and I'm not sure what to replace it with. I'd rather go aftermarket due to cost.
2. Can someone provide me with a headlight wiring diagram. The previous owner told me that the old headlight switch burned out due to a short in the circuit and I purchased a switch however I need to find where the problem is before I install the new switch. If possible maybe you can scan the wiring diagrams page and either post it or send it to my email, jeepcj@bellsouth.net
Thanks in advance. I generally do all the work on my cars and this being my first Porsche I'd like to make sure I do it right.
Regards,
JF
Old 02-12-2004, 12:17 PM
Chris_924s's Avatar
Antenna is power- If yours is permanently up- the motor is probably bad. I have left ine alone (broken in the up position) for over 6 years now.. wow has it been that long!
Headlight wiring diagram- check www.clarks-garage.com
or contact "Iceshark" on rennlist forums- He's the Light guy. Or buy a Haynes manual- all the wiring diagrams are in the back. (It's a 14$ confidence builder..)
Congrats on the 924S!!!
TENSION YOUR SOCKS!
88 924S Guards/ Black ~ 10 years as a Daily Driver and STILL SMILING!
87 NA Diamond Blue Metallic ~ Gone
Old 02-12-2004, 02:04 PM
entertaining the idea
UconnTim97's Avatar
Welcome to the bbs. You might be able to find them here too:
http://www.pelicanparts.com/944/electrical/944_electrical_diagrams.htm
Can't have to many resources
There are some who call me... 'Tim'.
a well set-up 1983 Guards Red 944
Old 02-12-2004, 02:05 PM
Chris_924s's Avatar
Tim.. congrats on Uconn.. Hella basketball.
I totally forgot about the online wiring diagrams here.. I'm slipping!
TENSION YOUR SOCKS!
Old 02-12-2004, 02:09 PM
SoCal Driver's Avatar
Use just the head and tail light circuits from the PelicanParts graphics. Some of the engine wiring is more like the later models than the early.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 02-12-2004, 03:43 PM
