My brakes= Broken
Now this is the story all about how my life got flipped, turned upside down and Id like to take a minute just sit right there ill tell you how I became the prince of a town called bel-air. Do do doot ding!
Well heres what happened. My brakes are screwed up. I push the pedal down and it goes all the way to the floor, i was like wats up with this crap? I can stop, but the pedal has to be near the floor. So i go home and check the resivour, MAN THERES NO FLUID IN THERE! So i get out the crappy DOT 3 Brake fluid that was in there and pour some more in. Then i drive it around, still no brake pedal, and i come home and MAN THERES NO FLUID IN THERE! So i just put some more fluid in there. Now, the fluid stays in there, except i still dont have a brake pedal. If i pump the pedal lots, it gets all nice and stiff, but as soon as i let off it, it goes crappy again. Looked at my kingdom I was finally there
To settle my throne as the prince of bel-air! CAN SOMEBODY HELP ME PLEASE
86' Porsche 944 N/a
Old 02-12-2004, 07:50 PM
Deplorable Member
Porsche-O-Phile's Avatar
Sounds like you have some serious air in the lines - bleed those bad boys!
'74 911 Targa 2.7 (in storage, hoping to finish "someday"), 2001 Mercedes SLK 320 (with a few AMG fun bits), '85 BMW K100, a few surfboards
Black Cars Matter
Old 02-12-2004, 07:51 PM
oo thats what my friend said, i hope Haynes has some thing about bleeding brakes, because if not, man im screwed! Also, which type of brake fluid should i get. It is an 86 N/a.
86' Porsche 944 N/a
Old 02-12-2004, 07:52 PM
If there's no fluid in the reservoir you have a leak. Bleeding the brakes is wasting your time and is potentially dangerous. Find the leak and fix it, then bleed the brakes. Sounds like the master cylinder has failed.
Never "bleed the brakes" air does not enter the system on it's own.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 02-12-2004, 08:05 PM
entertaining the idea
UconnTim97's Avatar
OK, I have to ask, what did you pay for this car?
There are some who call me... 'Tim'.
a well set-up 1983 Guards Red 944
Old 02-12-2004, 08:48 PM
payed 3000, there is fluid in the resivour, it is all in there now. I guess air enetered in there from fluid not being in the resivour.
86' Porsche 944 N/a
Old 02-13-2004, 05:33 AM
Sabyre's Avatar
But where did the fluid go?
Sounds like a leak to me. Even when your brake pads wear completely there is still enough fluid in the resivour to keep from letting air in the system.
Check your lines bro. Check the master.
Be safe friend.
"We are the music makers and we are the dreamers of the dreams" -Willy Wonka
Maine 4x4 Club www.maine4x4.org
Old 02-13-2004, 05:52 AM
Custom User Title
rammstein's Avatar
I'd have to think for your fluid level to drop from full to empty on a single drive, you'd have to have a big leak [deduced with my limited mental wherewithal].
Perhaps (someone correct me if needed) fill the reservoir with fluid, and have a friend start hitting the brakes while you look under the car for fluid leaks. (The car is parked during this ). That's where I would start until someone says otherwise.
Also, I would NOT drive the car until this is fixed. Brakes are important for stopping.
Old 02-13-2004, 07:10 AM
Yeah, but dude, there is fluid in the resivour. Right now, its full.
86' Porsche 944 N/a
Old 02-13-2004, 08:08 AM
Custom User Title
rammstein's Avatar
Oh- you've driven it and used the brakes and the fluid didn't drop? If that's the case, I'm stumped
Old 02-13-2004, 08:12 AM
Yeah, its full! ive driven it a lot since i filled it up again. I still dont have the brakes back to normal though. If i knew how to bleed the brakes i would try that.
86' Porsche 944 N/a
Old 02-13-2004, 10:57 AM
The fluid in there isnt clear though, when i poured it in it was clear, but now its all brown and foul. It looks pretty gross.
86' Porsche 944 N/a
Old 02-13-2004, 11:01 AM
Feelin' Solexy
Tishabet's Avatar
check out clarks-garage.com for an easy how-to on the procedure. On par with changing the oil in terms of difficulty.
Grant
1974 Vespa Rally 200, 1974 Vespa Primavera 125, 1963 Solex 2200, 1938 Buick Special, 2008 Mini Cooper S, 2010 Mazda CX-9, 1986 VW Vanagon Syncro Westfalia, 1989 VW Doka Tristar - in the stable
1989 Porsche 944, 1973 VW Beetle - gone but not forgotten
Old 02-13-2004, 11:08 AM
Burn the fire.
Brando's Avatar
Definitely flush your brake fluid system. Invest in a speed-bleeding machine, or a pump bleeder or get a friend and a 6-pack of beer to help you.
Get an instruction manual, too. It's too much wording for me to type up...
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 02-13-2004, 06:12 PM
