Head and Gasket Questions
Well, I got the 83 944 head back from the machine shop and all was well. I thought the valves must be bent, but nope. $65 bucks and looks like new. Thank goodness for a friend in the auto repair business.
BUT, I'm still concerned, because of the way the car ran. The head gasket looked bad but not blown. Frankly, the head didn't look bad when I removed it. There was a noise that sounded like a valve or something wrong on the top end. Also the leakdown test was like 4%, 30%, 34% and 18% front to back. I haven't examined the head gasket closely, but it did look "rusted" in some spots. I've had blown head gaskets before and I don't see anything dramatically wrong with this one.
The lifters and cam all look perfect, as do the cylinders.
Any ideas?
83 Silver 944/Auto/Cookie Cutters/No side strip moulding/Extra Saratoga top(w/no hardware though)
1980 Yamaha XS1100 Special My other project and daily driver
My kids say my hair matches the color of the car! Who's getting old?
Old 02-13-2004, 11:37 AM
tobster1911's Avatar
My 2 cents worth.....
Possible causes for low compression include (top down)
1. Bent Valves (very bad)
2. Scored Valve seats
3. Bad head gasket
4. Piston Rings
Did the machine shop actually disasseble the head and check the valves for tolerance?
I just had to go through the head of my '87 944S. Bent all the exaust valves. Damn timing belt.....
'97 Saturn SL (tiny 1.9L bubble car)
'98 Grand Prix GTP (4dr family car with a bite FOR SALE)
'87 944S (Sold as a German engineerd money pit)
'78 Chevy 4x4 (What I drive when everything else is broke)
Old 02-13-2004, 01:43 PM
Well that's a good question. A friend of mine who has an "auto salon" sent it out to a shop they use. I know they pressure tested it. I hadn't inspected the head gasket all that closely yet. I left it sitting in place until I was ready to clean and prep everything. I'll be home in a couple of hours and will certainly be checking it out.
It's the metallic noise throughout the RPM range that made me think it HAD to be bent valves. Ran real rough at idle, fine above 1000 rpm.
thanks.
Old 02-13-2004, 02:04 PM
FLA944's Avatar
Send a message via AIM to FLA944 Send a message via Yahoo to FLA944
Please tell me you did not reuse the head gasket.
did the machine shop plane the head?
Did you apply assembly lube to all contact points and fill the lifters with oil?
Did you apply assembly lube to the head bolts and torque in progression per the manual?(for accurate torque)
What is the compression? good compression = rings ok. Leakdown is either valve seats or head gasket.
Oh yeah forgot, low rpm NG above 1000 ok could be the intake gaskets. Use a bernzo-matic torch UNLIT! and wave around the intake mount and afm connections etc. and look for a change in rpms
Rick
'83 944 "Guards Red"
New Everything (seems like)
16" 968 Wheels
has never left garage (yet)
Old 02-13-2004, 02:46 PM
