-   -   replacing front struts (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/149069-replacing-front-struts.html)
Macfreak007 02-16-2004 04:22 PM
my front driver side strut was bent so the shop i took it to put a crappy used one the car, the passenger strut is in good condition so the questiuon is should i try to find a used one of should i just order new koni's from paragon?
CSU944 02-16-2004 10:23 PM
Bent cartridge or housing?
..P 02-17-2004 07:02 AM
put them on in pairs two fronts, two rears, of the same manufacturer.
I recently installed new OEM Boge gas units on my '84, it wasn't too bad of a job, and the rears were a walk in the park. The fronts took some time and I actually had a buddy give me some help too.
P
SoCal Driver 02-17-2004 07:08 AM
Should always match the inserts when replacing one of the struts. If both had considerable mileage then replace both of them.
I had a strut that was bent so bad I could not get the insert out.
MixMasterK 02-17-2004 11:59 AM
Make sure you go in for an alignment after working on any part of the suspension including the front struts.
fast924S 02-17-2004 04:43 PM
I love doing alignments They pay 2hrs, an it only takes about 45 mins - 1hr
repoman 02-17-2004 10:55 PM
just put in pwr steering rack and got new strut inserts for $30 each.
my trusted shop quoted me $200 on labor which sounds about right
