Upper Balance Shaft IMP!!!
I need some advice! Last night i was driving and my engine all of the sudden sounded louder and started vibrating really harshly so i took it into a shop this morning and found out that my Upper Balance Shaft had seized. they said it will cost between $1200-$2400. i cannot afford that. i was wondering if i should try selling it as is or parting it out, any other suggestion are gladly accepted as well... thanks
early 85 944
Old 02-17-2004, 12:41 PM
fast924S's Avatar
Send a message via AIM to fast924S
fix it your self. Just take it apart and replace the bushings and find a used balance shaft. Or I have a engine from a late 85 944 Will sell for $600 plus shipping. Then you can just swap engines
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 02-17-2004, 12:50 PM
TCMdocs944's Avatar
The upper balance shaft is pretty easy to get at...it seems.
Sounds like the shop is trying to give you the shaft............................................. .................................................. .................................................. ...............(i kill myself sometimes)
83 944 white w/Boxster wheels
Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
Old 02-17-2004, 01:05 PM
Send a message via AIM to Jason White
Sounds like they are trying to sell you new parts because labor shouldn't be more than three or four hours. Look for a shop that will install used parts and search for the parts you need on the forum. That will save you a bunch.
Jason
1987 924S White
-daily driver w/86k miles almost stock-
1971 914 Red
-doesn't see road much-
Old 02-17-2004, 01:54 PM
ae1969's Avatar
Send a message via ICQ to ae1969
Upper shaft seized ??? Thats not very common....
Uhmmm ... did the balance belt snap or just get stripped? It must have? your lucky the timing belt did not get caught up.....
I am pretty sure the balance shaft bearing bridge is machined with the block? I am wondering if they are thinking that they may need to pull the engine and have it machined ?
If thats the case its probably cheaper to find a used engine and swap it out.
Good luck.
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 02-17-2004, 03:13 PM
TCMdocs944's Avatar
Biggest suggestion here is
Get a second opinion.
Old 02-17-2004, 03:18 PM
Balance shaft failure is rare, you need, as noted above, a second opinion. If the bearing in the block that failed, you will be buying another engine, as all the metal pieces are now distributed through the oil system and to repair the rear bearing housing (in the block) means major engine disassembly. You need to get a written estimate of the repairs.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 02-17-2004, 07:18 PM
CSU944's Avatar
CrUeL-
I have an upper balance shaft and cover for your engine. If it turns out that all you need is the parts and not a new engine, PM me and we'll work something out (really cheap). You'd need to get new bearings and seals for it, of course.
Old 02-17-2004, 10:17 PM
Zero10's Avatar
Send a message via ICQ to Zero10
I say you tow it home, pull the balance shaft seal and take a look at what is going on in there.
You have a decent chance that you can just replace bearings, seals, and a new balance shaft and be on your way.
Worst comes to worst, you can swap the engine. It is not that hard, and there are plenty of people here that would be glad to help.
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury!
Buy my parts!
Old 02-18-2004, 09:36 AM
meister member
speedracing944's Avatar
I remember reading some where that if you disconect the balanced shafts you can gain 7 hp. The down side is the motor shakes like a mother.
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 02-18-2004, 10:15 AM
thank you CSU944... if i do take you up on that what else do i need to buy to finish the job and how much will it cost?
early 85 944
Old 02-18-2004, 10:19 AM
CSU944's Avatar
It'll be cheap if you can do it yourself; new balance shaft belt, new bearings, some Loctite 574 to seal the cover, new seals for the shaft, and about 3 to 4 hours labor. Parts shouldn't cost more than about 75 bucks or so through Pelican Parts.
If you don't feel comfy doing it yourself, I'm sure that AFJuvat or SoCalDriver can give you a good figure on what a shop would charge for the job.
There is a lot of info on this forum about how to properly install and tension your belts. Pay attention to the procedures if you do it yourself, otherwise you'll join the Order of the Bent Valve.
Yopu also have a PM.
-Tom
Old 02-18-2004, 10:37 AM
do i need to get a rebuild kit for the bearings and seals.. and is it a pretty easy job?.. i am an amatuer..
early 85 944
Old 02-18-2004, 10:40 AM
fast924S's Avatar
Ya I have seen Balance shaft deletion kits. They say you gain any where from 7-10HP But again its hell on the motor and anything bolted to it.
Old 02-18-2004, 01:12 PM
