Send a message via AIM to ColeLauterbach
I think I have the same leak. Did you ever find the culprit? Reading these posts suggest that I check the OP sending unit. I think also, that the oil cooler housing would be leaking water, not oil...
Hoplessly cleaning my fingernails
1984 944, 1996 Jetta, 1998 New Beetle, 2001 Passat, 1997 Expedition, 2004 Yamaha FZ6, 1985 & 1987 Suzuki LT230S, 1982 Cessna 172, 1989 Bayliner Capri 5.0 HO
Toys are Good.
Old 10-24-2004, 07:10 PM
Send a message via AIM to SlowToady
I DID change the oil filter w.i.w.i.t. with the seals...Could I have screwed that up?
IMO, probably not. It would more than likely drip more than a few drops every few hundred miles. If it's not tight enough, that's easy to check, just give it a nice turn with your hand and a shop towel. If the oil gasket were bad, you'd notice quite a bit more oil. Like, it'd be on your driveway/highway, not in the block.
When I did my belts, I didn't bother to reseal the front of the engine because it wasn't leaking, and I was really careful when I did it so I don't have too much useful input.
I turn away with fear and horror from this lamentable sore of continuous functions without derivatives. --Charles Hermite
Fakelife.com Nothing to do with archery anymore. Porsche/BMW/Ferrari/Honda videos
Old 10-24-2004, 07:32 PM
Send a message via AIM to bluebullet
hmm that is quite odd. My oil filter used to drip quite a lot of oil, but i wasnt using a factory filter. I used a Hastings, and the ring is too small and it doesnt sit all the way on the filter housing. Its so small it actually will cut up the rubber ring, and it leaks pretty bad. My front subframe under the filter and all along underneath that car is all gritty and grimy now because of it. My oil press sender was leakin a little, so I pulled that out and put teflon tape around the threads to seal it up. So far its been bone dry since.
1985 944 / 2007 335i / 1987 325is / 1985 535i / 1999 528iT / 2006 X5
Old 10-24-2004, 11:10 PM
/*In response to bluebullet*/
That's pretty odd, I can't believe they'd market a filter for your car (the 944 or the Colt?) that obvioulsy isn't designed properly. I'm sure it would have been such a huge engineering feat for them to fix that...::shrug:: That's one of the reasons I stick with well known filters. My oil filter housing is bone dry using a Napa filter (made by WIX).
In any event, it's been my experience that if a gasket is bad (not improperly designed, but defective) it will leak a lot of oil VERY quickly, and it will be everywhere. All over. I don't see it very often (thank God, what a mess to clean up), but after 5,000+ oil changes I've seen my fair share. TCM, if the problem was with the oil filter gasket, it'd be much more obvious (IMO). On a side note though, this last Saturday I got a Taurus with a bad gasket come in, and the next filter I grabbed leaked, too! Third time was a charm, no leaks. Kinda a ****ty way to start the day...
Figure it out and tell us, inquiring minds want to know, TCM!
Old 10-25-2004, 05:45 PM
ae1969's Avatar
Send a message via ICQ to ae1969
Get some engine dye.........and a black light.
No need to de-grease engine or nothing. Just throw it in! Run for 10 minutes and start looking.
No guessing.
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 10-25-2004, 05:55 PM
OK guys, i am new to 944s and guess what? Mine is leaking too... and badly. Id say 3 pints a month.... Whats the best way to know from where its leaking? What are the USUAL culprits? Thanks for helping.
PCA Member
2009 Audi A3 2.0 Quattro
1978 911 SC Targa
Old 10-25-2004, 06:49 PM
The oil filter prob was for the Porsche. the one i have on the colt has a very wide surface area for the gasket to sit on and it has nice rounded edges....its not a cast part like the Porsche one is.
So whatever you do guys, stay away from Hastings filters. They dont fit the 944. I went thru 2 because i didnt have a choice and they leaked like hell cuse of me splitting up the o-rings..
Old 10-25-2004, 08:15 PM
AFJuvat's Avatar
It sounds like you have a leak at the front main seal (for the bottom leak) I would venture to guess that your seal is installed incorrectly, or the wrong seal was installed. Also, are you sure you installed the O-ring behind the crankshaft pulley? If you installed the pulley, are you sure you put the washer that goes between the O-ring and pulley back on?
ANother possible cause (though it seems unlikely from your description) is that you switched balance shaft seals. the upper seal is supposed to be 47mm, the lower one is 48mm. If you get them switched, they will leak.
The upper leak coming off of the oil cooler\pressure sender is a tough one - many front upper engine leaks wind up at this location to drip off.
A few of the possibilities are:
Bad filter seal\extra oil filter gasket
Camshaft seal incorrectly installed\wrong seal installed
Camshaft pulley rear housing o-ring
Camshaft Mylar (onion) seal between camshaft and Camshaft "nose" piece
Camshaft rear pulley housing oil return O-ring\seal (that small little rubber seal on rear of rear pulley housing)
Valve cover gasket
Failed oil cooler gasket\seal
With the engine cold and not running, start at the top of the motor in and around the front of the camshaft and start feeling\looking for oil and work your way down. If you find a wet spot behind and just belowthe camshaft pulley housing, you've most likely found the source of your leak.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 10-26-2004, 04:52 AM
TSNAPCRACKLEPOP's Avatar
man, i am sure happy to know this board, and its members, will be there if and when i need them!! thanks juvie, from all of us!
dr tom
chance favors the prepared mind
1987 944 n/a 5spd. who remembers dial phones?.
'STOP FIXING THINGS ONE STEP BEFORE YOU BREAK SOMETHING ELSE"
Old 10-26-2004, 08:14 AM
TCMdocs944's Avatar
*this was a resurrected post, I fixed the problem in feb*
Now, here is what I did wrong.
I slightly damaged my upper balance shaft seal upon installation. It was sending oil up and along the case seal.
Coincidentally at the time my cam housing gasket had settled from the valve job I did the previous year. My cam bolts were all a few nm's loose.
Tightened up, leaks stopped.
Exercise great care with the balance shaft seals. I am not a mangler, it was just 'slightly' damaged.
Thanks for all the new help though
83 944 white w/Boxster wheels
Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
Old 10-26-2004, 08:32 AM
