TCMdocs944's Avatar
Unhappy Drip, Drip, Drip ... where is it from?
Did my front oil seals...runs great, sounds great.....Screwed up.
There is quite the oil leak coming from behind the rear belt cover.
Rate 1/4 quart per hour
Drip one - at bottom of crankcase behind belt cover..Above oil pan.
Drip two - between oil press. sensor and oil filter housing dripping off of a "wire bracket holder"
I assume the two are coming from the same leak, just taking different paths. Belts seem to be dry and no oil is in the bottom of the belt box.
Any Ideas?
Any common errors?
I just don't feel like removing all the belts and rollers to check it out unless I need to.
Possible hint - I installed the crank drive gear backwards the first time
83 944 white w/Boxster wheels
Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
Old 02-17-2004, 01:16 PM
Feelin' Solexy
Tishabet's Avatar
Ouch, that sucks!
Grant
1974 Vespa Rally 200, 1974 Vespa Primavera 125, 1963 Solex 2200, 1938 Buick Special, 2008 Mini Cooper S, 2010 Mazda CX-9, 1986 VW Vanagon Syncro Westfalia, 1989 VW Doka Tristar - in the stable
1989 Porsche 944, 1973 VW Beetle - gone but not forgotten
Old 02-17-2004, 01:30 PM
TCMdocs944's Avatar
Yes it does.
Old 02-17-2004, 01:48 PM
TSNAPCRACKLEPOP's Avatar
black gold, the pelican grief
well, if it is real clean, and you are sure it is engine oil, it can only be the crank pulley(which you had a problem with), or a bal shaft. i was such a chicken that i have not yet put the front cover on, so i could observe problems. i have a small leak, like 3 drops a day after shut off, which i am sure is the lower bal shaft seal. ( you know about the directionality of the seals on the shafts, the lower one has the left handed or universal direction seal?) i suggest taking off the front cover, wiping it down with a rag, let it run a few min, and see whats up with the dripping down.
could it be power steer fluid? hope,hope!
justt got back from colorado, 85 plus most of the time, and 31 mpg with the lights off.
can you send a pix of where the drops are at, like a clean piece of cardboard under the parked car, with the relative position of the front bumper in the view? well lit?
dr tom
chance favors the prepared mind
1987 944 n/a 5spd. who remembers dial phones?.
'STOP FIXING THINGS ONE STEP BEFORE YOU BREAK SOMETHING ELSE"
Old 02-17-2004, 01:56 PM
todwic's Avatar
Send a message via AIM to todwic Send a message via Yahoo to todwic
Did you apply a light coat of oil on the seals before you installed them?
*Disclaimer: The person above is actually dumber than he appears.
my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements
'84 944 auto/ps/ac/cc
'86 951
Providing ignorance one post at a time.
TCMdocs944's Avatar
Oiled the seals
Dont have power steering
Direction right on the balance shaft seals
Q - Can I pull/check the crank seal without removing the whole shibang?
(cant remember)
Old 02-17-2004, 03:16 PM
its hard to get the impact wench in without pulling the radiator and fans, or a big long breaker bar would do it, but no room to work.... of course the belts (ugh) must be removed. Mark the direction of their rotation.
Old 02-17-2004, 03:23 PM
repoman's Avatar
gee, this sounds familiar. dealing with same but less leakage from my seal change.
since belts are dry and leak is small I'm going to let it go until I fix cam cover leak
noticed there is a small hole in extreme bottom of timing cover so perhaps porsche designed an escape route for small amounts of oil to protect belts?
'84 944 auto stock
Old 02-17-2004, 10:01 PM
TCMdocs944's Avatar
I GUESS I am going to have to remove the belts and rollers again....
......DAMMMMMMIIIIITTTTT.....
Well, I guess it should be pretty easy the second time around. Already have all the parts and they are all clean. Just monkey disassembly and reassembly with german precision.
Old 02-18-2004, 09:03 AM
Zero10's Avatar
Send a message via ICQ to Zero10
Hmm, I have a leak in a very similar location, I think mine is the oil cooler seals. Have you checked them out?
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury!
Buy my parts!
Old 02-18-2004, 09:31 AM
TCMdocs944's Avatar
Did my oil cooler one year ago...........Hmmmmmm
Maybe my seals were ok all along????
Maybe one of the cooler bolts backed out or the gasket "settled"
Maybe the drip is going from the cooler along under the cover towards the front?
Hmmmm
One key fact though....Only leaks with compression....Not when shut off.
Old 02-18-2004, 12:05 PM
repoman's Avatar
I'm kinda hoping once my cam cover leak is fixed, leak in front disappears
wishful thinking
'84 944 auto stock
Old 02-19-2004, 06:56 AM
TCMdocs944's Avatar
I think the oil cooler cannot be the culprit....Wouldn't it be leaking coolant only and AFTER I shut the engine off and it cooled?
My thoughts now are that both leaks are from one source...one taking the high road the other the low. That is my hope anyway.
Tommorow I will pull down until I find it.
QUESTION - How will I find the leak if it only happens during running especially when I have just cleaned everything weeks before? Tale tell "dirt" trail probably won't be there and no starting w/o the belts.
Old 02-19-2004, 08:04 AM
TCMdocs944's Avatar
Pulled the WHOLE front off this weekend.....
very very slightly suspect lower balance seal.
Pulled it...reseated it.
Everything back together....SAME LEAK.
No oil in belt box at all. Crank seal dry all others appear dry?????
Noticed it looked more like area around the oil cooler had drips.
Did I do the whole front seal job for a leak elsewhere?
Any Ideas?
Old 02-23-2004, 06:02 AM
TCMdocs944's Avatar
Bump
?What are pressure relief valve symptoms?
Old 02-23-2004, 07:24 AM
TCMdocs944's Avatar
Drip
Drip
Drip
Ok, you guys usually answer in like one hour or better, I always brag about you to my friends.....What gives? Did everyone get jobs? Is the boss cracking down on internet usage? Are you all out there doing chia mods? Come on guys... simple oil leak.
Wire bracket in front of oil pressure releif valve
Oil cooler seems to have oil dripping occasion. but only lower half.
........Possibly seperate
oil pan under and to left of crank...coming from above somewhere
Sheesh....This may actually take a few hours to figure out ;-)
Old 02-23-2004, 11:51 AM
i hope your leak is the same as mine, so 2 birds are stoned at once. i will look under mine tonite., it must be engine oil as it is so clean, 3 drops per,stop, 2500 miles. i comes from the area of lower bal, but i will look close tonite. could be st elsewhere.
dr tom
Old 02-23-2004, 12:01 PM
TCMdocs944's Avatar
Mine seems the same area Tom but..
Belt box is absolutely dry. Lower balance housing the same. :-(
Maybe it IS seal oil like FR says.....(how did a seal get in my belt box?)
Old 02-23-2004, 12:04 PM
FLA944's Avatar
Send a message via AIM to FLA944 Send a message via Yahoo to FLA944
TC,
We want to help desperately but am dumbfounded as you are. When you put up the oilpan did you use sealant on the corners wher it curves?
Any chance to get it on ramps sart it up,crawl under it with a rag and purple power with it running clean a suspected area and watch it then move around (use of a halogen flashlight)
NOTE TO SELF! Have someone with you incase of something bad. I hate it when "bad" happens
Rick
'83 944 "Guards Red"
New Everything (seems like)
16" 968 Wheels
has never left garage (yet)
Old 02-23-2004, 05:23 PM
TCMdocs944's Avatar
Yeh, I know Rick...I really want to help myself too.
Nope to the oil pan thing....I think that may be one of my problems.
The other has me stumped. I have done just as you said with shop towels and the oil cooler area seems to magically get oil on the housing again.
I DID change the oil filter w.i.w.i.t. with the seals...Could I have screwed that up?
Guess I will just have to start checking torques and maybe pull the oil filter....
I will feel so dumb if it was the filter all along.
Old 02-23-2004, 06:10 PM
