meister member
speedracing944's Avatar
Lightbulb I found more cam belt tensioner testers
I came a cross a catalog of belt tensioners and I called the company to discuse tensioner testers. First of all he said the "Krikit" should not be used to do timing belts as it is not precise enough. I have found a couple of others that would work according to the tech rep. First of all they make 2 sonic tension meters. They operate by measuring the natural frequency of a free stationary belt span and instantly calculates the static belt tension based off of span length, belt width and type. He said this device is extremely accurate, much more than any mechanical means. They also have 2 pencil type tension testers that would work for us as well. My concern with those is they are tall (like a pencil) and I wonder if it would fit in the small space. The sonic tester has a "list price" of $1000 but I will contact a supplier to see what the actual cost is. Usually the list price is inflated greatly. I will keep you posted about what I find.
By the way they do sell 2 kinds of the Krikit also. The small one is $9 and the larger one is $13.
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 02-18-2004, 10:29 AM
TCMdocs944's Avatar
Bout time some new research on this topic came up. Seems ridiculous that we have to choose between a $500 tool and a $5 one.
Sonic tensioning - that sounds damn cool.
83 944 white w/Boxster wheels
Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
Old 02-18-2004, 10:59 AM
meister member
Thumbs up
When I get home I will post a pic of the catalog page with the testers. There are seven of them listed all together, 4 of which the tech guy said would work for us.
Old 02-18-2004, 11:14 AM
TCMdocs944's Avatar
Hopefully they will go the way of the pyrometer.
Those things started out in the $500+ range and now I have seen a few for less than $100
Old 02-18-2004, 11:22 AM
meister member
Here is some pics of the catalog. I am having a distributer work on some prices. He should get back to me on Thursday.
Old 02-18-2004, 02:04 PM
TCMdocs944's Avatar
Dont think you could get the pen version in the belt box.
Old 02-18-2004, 03:42 PM
AFJuvat's Avatar
FLA944 and I were going to test a sonic tension meter.
As soon as FLA944 get his hands on one from work...
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 02-18-2004, 05:04 PM
TCMdocs944's Avatar
Can't wait to hear how it turns out..
If you can get it in there without removing anything but the covers that would be great.
Even be worth drilling a hole in the cover that you could "shoot" through with the sensor.
Old 02-19-2004, 09:30 AM
meister member
I got a price on the sonic belt tensioner tester. They quoted $675. That is $180 more than the P9201 from Sunset Porsche. I am trying a different supplier to see what he quotes me. I will give an update when I hear something. The good thing is with it being electronic maybe the price will go down in a couple of years. The model that I am getting quotes on is the Gates 505C, product # 7420-0203 for anyone else who is interested in doing some home work. Good Hunting
Old 02-23-2004, 02:48 PM
FLA944's Avatar
Send a message via AIM to FLA944 Send a message via Yahoo to FLA944
Yup, that is the one we use and it is a $1000.00. Gates makes several models with varying options and reading outputs. The model we use is $1200.00 and has all the bells and whistles. We have to use that one as Gates warranties are belts for life and without it goodbye warranty. You would need to determine what the sonic tension you are looking for so you would have to test and record against; yup, you guessed it a car that was just done with the 9201. (must maintain a cal. control)
I thought about it and is not efficient for us to use one unless we do alot of belts and you would need to do alot of em for $1000. Heck, the 9201 is $500 and you would need the same justification. Our machines cost start @ $100,000.00 so a grand is minimal. They are very easy to operate. Measure the span from pulley center to center enter the width and thickness then hold the mike on belt and flick with finger repeat minimum of 3 times, we do about 10 to determine the average.
The Kriket/Optibelt seems consistent in readings and a very good inexpensive tool. Juvy and I did compare the optibelt against the 9201 do determine the graduation for the optibelt and it was consistent time after time. Note: the balance belt was very tough due to so much slack but was consistent as well.
I'm in SoCal all week and do not have it to tell you what the graduations came out to be, Juvy might?
Rick
'83 944 "Guards Red"
New Everything (seems like)
16" 968 Wheels
has never left garage (yet)
Old 02-23-2004, 04:55 PM
