Clutch job done, no speedometer?
Well my mechanic did the clutch job and was so frusterated with it I got the car back 80% done. Got it drivable today where all I have left is the downpipe. Only problem, my speedo won't read. Any ideas where to cheack what he may have missed?
Thanx...
BTW: The car is so smooth with the new spring centered clutch and new motor mounts...been so anxious to get this car back after 6 months
Yes the motor is in the front....
Old 02-20-2004, 10:03 PM
The plug to the left side of the transaxle.
89 951 Black/Black
Old 02-20-2004, 10:11 PM
Sabyre's Avatar
Why did he quit 80% the way through? Maybe you need a new mechanic.
"We are the music makers and we are the dreamers of the dreams" -Willy Wonka
Maine 4x4 Club www.maine4x4.org
Old 02-21-2004, 06:34 AM
Zero10's Avatar
Send a message via ICQ to Zero10
I think you should stop paying 80% of the way done, right before you hand him the cash. =)
Hmm, what year is yours? pre 85.5, and it's a cable on the front driver's side wheel, post 85.5, and it's an electric sensor on the transmission.
Given that it doesn't work after he had to remove the transmission, I would bet yours is post 85.5, and yep it's an electrical connector on the side of the transmission. Well there are 2, the backup switch and the speed sensor, I just don't know which is which.
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury!
Buy my parts!
Old 02-21-2004, 08:43 AM
well it was sorta a deal we worked out...I'd finish the exhaust part and he'd do the hard stuff. I'll check it out today...are the plugs in plain view?
Old 02-21-2004, 09:05 AM
SoCal Driver's Avatar
Plug. One. Over the top of were the left axle goes into the trans. The trans has a sender on it for the speedo.
Please and the year and model of your car to your signature line. Keep the rest of us from guessing wrong.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 02-21-2004, 09:21 AM
OH yea...it's an 85.5+ Well I just hooked up the exhaust and found the plug...Speedo works! All this time I've been driving the car with shot mounts and a bad clutch/throw out bearing. It is sooo smooth now. I think this car is a keeper for a long time. GOod to be back
Old 02-21-2004, 11:31 AM
