Sunroof & Rear Hatch Seals
Recently I purchased a sunroof seal (Pelican Parts) and a rear hatch seal (Vertex) for my 1978 924. During my attempt to install them I ended up with more seal than circumference of both the sunroof and the opening for the rear hatch. I made sure that both seals were well seated and I don't believe I did anything to "stretch" either of them during installation. Shall I get the scissors or have I used the wrong technique for installation? Suggestions will be sincerely appreciated.
Ken
1978 Porsche 924
Old 02-21-2004, 04:54 PM
Zero10's Avatar
Send a message via ICQ to Zero10
I know that when the PO installed my seals, he had to trim them, and now they have shrunk and have a big gap. If you trim them, make it a tight fit, so they don't leak as soon.
I think they give you an extra inch or two of seal in the kits though.
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury!
Buy my parts!
Old 02-21-2004, 05:58 PM
SoCal Driver's Avatar
I would try to work the hatch seal around so that you compress it to fit. As was noted; it shrinks. If you do cut it save the extra piece as you may have to ShoeGoo it back in.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 02-22-2004, 06:25 AM
I agree with you Hugh... but it pissed me off so I cut it anyway as Zero suggested. What looked to be a significant amount of "extra" turned out to be 1/2" so I might have been able to somehow work that extra 1/2" somewhere around the perimeter of the hatch opening. Maybe next time, huh?
By the way, not sure if this has been covered in the forum somewhere previously, but... is it just me or does anyone else think that big gap between the rear hatch frame and the body of the car seem like a styling error? I think I've seen other cars where a spoiler somehow fills the gap and makes it look better but on mine, it just seems like somethings missing...
Ken
1978 Porsche 924
Old 02-22-2004, 10:27 AM
How big of a gap?
Old 02-22-2004, 03:08 PM
FR, you know, after that line and that picture, I'm feeling alot better about ruining that seal...
Ken
1978 Porsche 924
Old 02-22-2004, 04:10 PM
ok, here's a picture of the gap. This is the first picture I've posted so if it turns out to be too small I've will post a a larger version.
Ken
1978 Porsche 924
Old 02-23-2004, 09:11 PM
