-   -   1977 924, interference engine? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/149934-1977-924-interference-engine.html)
Harpman2 02-22-2004 06:13 AM
My nephew got a rough 924, for $100 from a friend. It ran rough, so he started trying to fix "things". He took the timing belt off, I don't know why, something about getting to a thermostat. He claims he followed the manual (Haynes maybe) when taking the belt off and putting it on, and it did crank OK once he put it back on, but wouldn't fire up, so he redid the belt few times, God only knows what he was altering each time, and now it won't even crank even though battery is fine. If it is an interference engine, how much damage could he have done to the valves, just by cranking it with the battery? He didn't hear any large crashing sounds like I guess you would if the belt broke while driving. ....Kids.
rben 02-22-2004 06:57 AM
You are in luck. The 924 is not an interference engine.
Rben
scheistermeiste 02-22-2004 10:15 AM
the 924S is the interference motor
Manute 02-22-2004 10:26 AM
I want another running 924 for $100 :D
Harpman2 02-22-2004 02:01 PM
Thanks guys. I'll call my nephew and tell him he didn't total his engine.
Sabyre 02-22-2004 07:10 PM
Tell him to be a bit more careful. After all you should cherish any and all Porsches not experiment with them.
Porsche-O-Phile 02-22-2004 08:07 PM
Yep - non-interference (lucky him). If it had been a 924s you're looking at new valves (minimum), possibly new head machining, springs, piston(s), cylinder wall machining or sleeving, etc. . . the list of horrors goes on.
Please tell him to treat these cars with respect - a healthy paranoia about them keeps 'em around. . .
Trevor 02-22-2004 09:14 PM
Maybe you should refer him to pelican so the users of this board could help him get it running.
Harpman2 02-24-2004 06:30 PM
Thanks, I'll tell him all that.
