Post 944 Mods
Recently purchased 89 944...want to mod..but i have heard theres not too much you can do...any suggestions anyone..besides selling and getting a 951
Old 10-11-2001, 09:04 PM
Post
Chip it
Supercharge it
K&N it
Turbo charge it
Put a 951 motor in it
Piston it
throttle cam
Yellow sticker it
It depends on what you want to get from your car and how much you want to spend.
Old 10-11-2001, 09:11 PM
Rollins's Avatar
Send a message via ICQ to Rollins Send a message via AIM to Rollins
Post
Taking weight off helps a lot. Upgrading the ignition and wires helps. Get a new exhaust system with headers. Bursch seems to be well liked. Suspension work helps a lot too.
Old 10-11-2001, 09:14 PM
fty fty is offline
fty's Avatar
Send a message via AIM to fty
Post
I rip the entire interior out except the dash and drivers seat...will i see a big difference?
"Faster,Than,You"
"Wish I had a 951....."
"Ive tried so hard and got so far but in the end it doesnt even matter"
http://www.members.aol.com:/fty9999/944land/944land.htm
Old 10-12-2001, 04:59 PM
Rollins's Avatar
Post
Depends what you define as the interior. Ask Obin about his results. He did a huge make over on his 924. You can prolly take off a couple hundred pounds in the interior alone. Subwoofers in the trunk make a big difference. They weigh a lot.
Old 10-12-2001, 05:06 PM
Post
The weight-hp ratio is around 15. Does this mean that take every lb off will gain 1 hp? I'm not sure its right way to culculate.
Old 10-12-2001, 05:10 PM
Bob's944's Avatar
Send a message via AIM to Bob's944
From what I've seen, do not turbo it or supercharge it... it'll end up a nightmare. You can... chip upgrade ($150-$300), exhaust w/ test pipe ($200-$500 and up to $1,000), K&N ($60), Ignition upgrades ($50-$500), 50-60HP nitrous kit ($600), Bore throttle body ($350), Aluminum flywheel ($700 plus labor), add a stroker kit ($??? ...bet it's pricey, but it would make a 3.0L 8v). Then of coarse you have to beef up the suspension with springs, torsion bars and shocks.... maybe some brake upgrades too..... fun fun fun
Old 10-12-2001, 05:13 PM
JB2 JB2 is offline
Post
AT THE TRACK I RUN (AT BEST 89 MPH),THE TURBOS WERE RUNNING 99 MPH, IS IT WORTH IT?
MSD 6A,JACOBS WIRES,BOSCH 15V COIL,+4'S,THROTTLE RESPONCE CAM,CUSTOM COLD AIR INTAKE,K&N FILTER,BURSCHE HEADERS,2 1/4 PIPING,HIGH FLOW CAT,FLOWMASTER 3 CHAMBER, TURBO FRONT END,MOMO STEERING WHEEL,STRUT BRACE,KYB'S,MOROSO BATT. BOX AND CUT OFF SWITCH,KENWOOD CD,AUTOMETER TACH AND OIL PRESS GAUGE,SUMMIT DATA RECALL SYSTEM,FALKEN TIRES,EPSILON TWO PIECE RIMS.
Old 10-20-2001, 08:32 PM
Post
how much of a difference would chip, exhaust,k&n, and a low cost ignition make?
why does changing the ignition increase your speed? please explain.
oh, and what year was the 944 changed to when you could add a chip?
[This message has been edited by ranbok (edited 10-20-2001).]
Old 10-20-2001, 10:58 PM
Bob's944's Avatar
chips plug in on 85.5 and newer... the older models can take chips, it's just alot more because it's not just a chip... they get 10-15 HP but you have to pump premium only too.
exhaust can be 10-20 HP depending on how much you do, with the most coming from a test pipe arrangement.
K&N and ignition upgrades don't add much HP, maybe a couple each if yer lucky, but should help with efficiency and gas milage.
Old 10-20-2001, 11:38 PM
