fender removal
so i think i've removed all the bolts holding fender on, including the 3 on the door side under the undercoating but i cant take the fender off. could all the undercoating be holding it on? or are there other "hidden" ones? if its the undercoating how does one go about removing it? i used a knife to cut the bolts out but it was a pain.
1987 944S
Old 04-03-2009, 02:23 PM
Catamax944's Avatar
Its kinda "glued" to the inner fender.Just get a heat gun and putty knife and clean the inside edge of seam sealant and undercoating.
I'm sure there's a DIY somewhere that explains it very clear but i can't seem to find it right now.
If you plan on throwing it away and changing it just pull real hard on it if you have the courage,it will come off.
Catalin
'86 DD
Old 04-03-2009, 02:59 PM
Theres a screw from the header panel to the fender, plus the 3 holding the front valance to the fender.
Old 04-03-2009, 05:03 PM
Custom User Title
mikepellegrini's Avatar
My kid just did the fender on his 951 and they ended up having to (very carefully) heat up the seam to get the glue to let go. Used a teeny weenie butane torch.
83 944 NA - Black on black
86 951 - Red - SOLD 7/21
16 Ford Expedition
He who hesitates is lost.
Old 04-03-2009, 09:34 PM
