944 belts
I'm trying to help a friend with his 84 944. Has water in oil and wasn't running. He had head and belt problems before and only about 15k on new belts. Haynes manual says to take to dealer for belt tensioning. Can someone explain the purpose of the balance shafts? I have worked a lot of older US engines but don't understand the purpose of these shafts and the manual we have doesn't describe their purpose. I want to learn as much as I can prior to tearing the engine down. All help will be appreciated.
Old 02-25-2004, 10:37 AM
Feelin' Solexy
Tishabet's Avatar
Check out clarks-garage.com for great and in-depth info about these belts and shafts. Also, water in the oil is your oil cooler....good procedure for the fix at clark's also
Grant
In the stable: 1938 Buick Special model 41, 1963 Solex 2200, 1973 Vespa Primavera 125, 1974 Vespa Rally 200, 1986 VW Vanagon Syncro Westfalia, 1989 VW Doka Tristar, 2011 Pursuit 315 OS, 2022 Tesla Y
Gone but not forgotten: 1973 VW Beetle, 1989 Porsche 944, 2008 R56 Mini Cooper S
Old 02-25-2004, 10:38 AM
SoCal Driver's Avatar
Get the Haynes manual too. Where are you located?
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 02-25-2004, 10:41 AM
Clarksville Tennessee
Old 02-25-2004, 10:44 AM
ae1969's Avatar
Send a message via ICQ to ae1969
the balance shafts are meant to maintain harmonic balance... (2 counter weights on either side of the engine)
Without the belt there is a shake around 4K rpm.....
BUT if the counter weights are out of alignment it will shake like a washing machine.....
Welcome.
but if the belts are
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 02-25-2004, 10:46 AM
"but if the belts are....."
Suspense! I can't stand it!!!!
Old 02-25-2004, 10:54 AM
TSNAPCRACKLEPOP's Avatar
we have a few posters who are from your area who may be able to assist you, but if you have worked on cars, you can do this job. do lots of reading beforehand, as i heard somewhere that "chance favors the prepared mind"
good luck!!!
1987 944 n/a 5spd. who remembers dial phones?.
'STOP FIXING THINGS ONE STEP BEFORE YOU BREAK SOMETHING ELSE"
Old 02-25-2004, 10:56 AM
TCMdocs944's Avatar
Sounds like you have a couple of concurrent jobs ahead of you.
Belts
Oil Cooler
If the belts have "gone" head needs a fixin.
Check for valve damage by rotating the crank clockwise -battery disconnected, out of gear- and see if you encounter any significant resistance = bent valves = $500 min parts and head labor(you pull the head)
Hey, you could always buy the buddies car cheap and join the board!
Good luck.
83 944 white w/Boxster wheels
Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
Old 02-25-2004, 01:28 PM
Sounds like the more questions I ask the more questions I have. For a guy who just retired it sounds like I have started a new career. The manual I have sucks as anything complicated it refers you to a dealer but goes into great detail on rotating the tires. Tell me more please.
Tennessee Tom
Old 02-26-2004, 06:32 AM
TCMdocs944's Avatar
Factory manuals + haynes + Clarks-garage.com = usually you can figure it out with the three of them.
Try Clarks-garage.com , go to the online manual section.
If you have specific questions as you are getting into it just let us know or try the search button here. The search helped me with 90% of my repairs in the beginning.
Old 02-26-2004, 10:34 AM
