				dome light
			for 1988 944 n/a dome light.
				rear-most position means always on. Works on mine. forward most is what? On when door open, or always off . middle position is what? On when door open, or always off. when my door is open the light won't come on in either of these positions, anyone know what I should check for, bad wire etc thanks
	Red 1967 Saab "96", needs help Blue 2002 Pathfinder SE 1991 240SX-SE, auto, trans was shot - junked it  |
			I have the same problem.
			Front is supposed to be with the door. My door buzzer comes on which tells me the door switch is operating. I think my actual light switch may have a bad connection...
	83 944 white w/Boxster wheels Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
			Something is wrong with mine too, It seems like the swicth went to ****, It feels all weird and stuff,  You cant even feel the notches for the different possitions anymore, and it doesnt work at all,  SO I guess I will be looking for a new one.
	1986 951, Stock for now. ]87 924S Gaurds red- SOLD after 11 years of ownership  |
			The Fwd position is the door light, Mid Position is the Off, and aft is on.
	They're about 8 bucks from of all places PELICAN lol But seriously,, There are a few ground wires connected to one end and a single large power connection on the other. you could use a meter scheck the grounds are working through the door switch.  |
			Mine never worked when I bought the thing...
	Then one day I pulled the assembly down and noticed that the plastic had melted where the lever moved on and it was not making contact... so I rigged it to work temporarily untilll I can get a new assembly... I've seen them for about $12 with the bulbs. Check here at pelican first, I think they have them. Don  |
			Here's the quick way to find out:
					http://www.pelicanparts.com/catalog/shopcart/944M/POR_944M_lenses_pg3.htm#item14 That will take you right to the interior lamp.. I was wrong ealier, they're 5 bucks....  |
