Post shifter vibration
My shifter vibrates at about 3k rpms, but disappeares after that. It only seems to do it while its in gear. Like if I have it in neutral and rev it up it's not there. Also it does this in every gear so it's not a particular speed that does it just a particular rpm. Any ideas?
Old 10-27-2001, 10:32 AM
Scott R's Avatar
Post
When did you change the clutch last, sounds like a throwout bearing on it's way out. Of course I seem to remember another member that had this symptom and it turned out to be his torque tube. Better check the archives.
Old 10-27-2001, 11:20 AM
Send a message via ICQ to diannone
Post
some custom shifter knobs will vibrate noisely? if not installed correctly. does yours fit that catagory? my new momo raptor knob did till i installed it corectly on the speedforce short shifter.
Old 10-27-2001, 11:23 AM
AFJuvat's Avatar
Post
Hopefully it is not your clutch or torque tube (though that is a possibility) One other thing to look at is the connection between your shift rod and the linkage itself - it wears out. Also, when you car is in neutral, is the stick centered in the grarbox? If it doesn't center itself, your linkage needs to be adjusted.
Fingers crossed for you that it is something cheap.
AFJuvat
[This message has been edited by AFJuvat (edited 10-27-2001).]
Old 10-27-2001, 09:42 PM
fty fty is offline
fty's Avatar
Send a message via AIM to fty
Post
IT is your clutch...rubber bushing went gaureenteed..new clutch kit...389 at www.**********.com
"Faster,Than,You"
"Wish I had a 951....."
"Ive tried so hard and got so far but in the end it doesnt even matter"
[URL=http://www.members.aol.com:/fty9999/944land/944land.htm]
Old 10-27-2001, 11:54 PM
Petie3rd
Mrmerlin's Avatar
Post
[QUOTE]Originally posted by eligunn:
Hi Eligunn, if you feel like doing some searching remove the shifter boot and see if the shifter linkage is tight or loose either way take it apart and lube it with some grease,
If you know you have a good clutch, look for lil pieces of rubber coming out of the bottom of the bell housing (Blown Disc)
I would check in this order
The motor mounts
Trans mount and shifter index bolt on the trans axle shift linkage (It is safety wired, and under the rubber boot)
C V Joints
Balance belt timing
Bell housing bolts to engine
Trans axle to torque tube bolts
Driveshaft to input on the transaxle coupler
Good luck .........Stan
Old 10-28-2001, 12:48 AM
Post
Had vibration & a roar developing in 82 924t at 3000 rpm, every gear & nuetral. It was the torque tube.
drew1
Old 10-28-2001, 07:33 PM
Send a message via ICQ to Anger944
Post
It's the Clutch, replace the entire clutch system. Resurface flywheel, new bearings, etc.
Old 10-28-2001, 08:26 PM
Post
there's lots of good responses here - are you asking how to resolve the vibration or the outcome of the vibration, like rattling noises coming from the shifter? In replacing the factory shift knob with a Momo, I did find small gaps in the linkage can really cause an annoying rattle at low RPMs. Some very thin spacers took care of it but it was tricky trying to locate the rattle as it transmitting throughout the shift mechanism.
Old 10-29-2001, 12:52 PM
Post
Have to agree it really sounds like the clutch. I had the same problem after I let my "friend" drive my car home from a bar after I hooked up with a chick. The first and last time I ever let someone take her with out me! Dealer installed, $1200!
Old 10-29-2001, 02:09 PM
Post
thanks guys. I'm sure its the clutch. I found some rubber.
Old 10-30-2001, 03:14 PM
