clutch question
Just got the clutch and pressure plate out today. The symptoms that I had (excessive driveline lash and the clunk going on and off throttle) I diagnosed from other threads as a bad rubber center unit on my clutch. You guys provided the info for an accurate diagnosis, thanks alot, I mean that. You guys help more than just the guy asking the question when you take the time to share your knowledge.
Anyhow, should I resurface the flywheel? I was having no problems that I know of with the flywheel, and don't want to waste time and money that could be better used. But, if it should be done, I don't want to be foolish, especially when it won't take much at this point.
For those who took the time to answer my questions about my sensor bracket thanks alot. It came out with the sensor, when I removed the clutch housing. The sensor needed to be hammered out. There was no way to remove the sensor without the bracket.
'86na, 5-spd, turbo front brakes, bad paint, poor turbo nose bolt-on, early sunroof switch set-up that doesn't work.
Malo periculosam, libertatem quam quietam servitutem.
Old 03-03-2004, 03:38 PM
ae1969's Avatar
Send a message via ICQ to ae1969
You should resurface the flywheel. It will only cost you 20 bucks....
You can get some vibration if the surface is not up to snuff.
Good luck and have fun.
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 03-03-2004, 03:51 PM
Thanks, just the kind of response I'm looking for.
Oh, and don't worry about the fun.
Old 03-03-2004, 06:06 PM
SoCal Driver's Avatar
Most all sensors stick in the bracket. Sometimes the bracket will break trying to remove them.
As to cheap clutch jobs: If you have done a few clutches then you can determine if the TO and pilot bearings need to be replaced. Same for the pressure plate.
You do need to lube the guide tube for the TO bearing.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 03-03-2004, 10:31 PM
