Post speedo
My speedo stopped working and I need to fix it so I can see how fast I'm going when I pass those Fords.
Old 11-03-2001, 07:12 PM
Post
As long as those fords don't have flashing lights, your ok. Until you get it fixed use the tach.
Joshua Harrison
Porsche owner at heart
Old 11-03-2001, 07:50 PM
Post
Interesting. Both my speedo and odometer stopped working (common Porsche problem) and I didn't notice at all (for at least 6 months as deduced from my service records). I would notice immediately if the tach went, however!!!
I wonder how many other Porsche drivers are like me? (Actually, I suspect many drivers don't look at their speedometers, regardless of type of car)
Old 11-03-2001, 09:46 PM
Composite Shop Owner, DJ
MixMasterK's Avatar
Send a message via MSN to MixMasterK Send a message via Yahoo to MixMasterK
Post
Mine just likes to jump from 0-140 in 1 sec. intervals. Need to get it rebuilt.
Old 11-03-2001, 10:07 PM
Send a message via Yahoo to Cebu
Post
If you have a 944 model 85.5 and later...the jumpimg speedometer is most likely a bad transmitter (it screws into the top part of the transale assembly).
Old 11-04-2001, 05:10 PM
stray15's Avatar
Send a message via AIM to stray15
Post
I believe the common Porsche problem is just the broken odometer.
If your car is an early one, I will bet that it is a broken speedo cable, happened to mine. Easy fix but kind of time consuming.
What year do you have?
Old 11-04-2001, 05:44 PM
