Taking out Dash Easy?
How hard is it to take the dash out? I wanted to get my cracked dash redone in vinyl and the bottom part of the dash redone also.
------------------ 85.5 Porsche 944 |
It's not that hard, though it will take you a couple hours possibly. Two screws on each side as well as a nut behind the center speaker. Pull the instrument cluster and be sure to mark where all the connections go. Don't mix up the wires on the tach or you'll blow a resistor inside. Other than that, have fun.
Ok.. how about a late model with airbags?
| All times are GMT -8. The time now is 07:43 PM. |
